Facebook Twitter
H22 Swap into '99 Civic *PICS*
This is a discussion on H22 Swap into '99 Civic *PICS* within the HYBRID -> EG-EK / DC forums, part of the Hybrid Forums category; Wiring up the H22 (using P13 ECU and modifying the Civic harness) I didn't have the bracket to hold the ...
Old 11-04-2006, 09:20 PM   #1
Dr Tweak is on a distinguished road
Default H22 Swap into '99 Civic *PICS*
I didn't have the bracket to hold the timing belt tensioner, so I whipped this up in a few minutes with a spare bracket, a hammer, and a cutting wheel...
It doesn't seem like it could fit!
PUSH! PUSH!
More to follow this coming week =) See more of my swaps at Phoenix Tuning - Home and PSD_Home
Dr Tweak is offline   Reply With Quote
Old 11-04-2006, 09:36 PM   #2
THE CHRIS
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
nice!
i hope that bracket holds
TurboMirage is online now   Reply With Quote
Old 11-04-2006, 10:22 PM   #3
Oh no, that bracket doesn't stay there, it just holds the hydraulic tensioner in a compressed position so that I can slip the new timing belt on. Then it's removed and it tightens the belt up.
Old 11-18-2006, 03:24 PM   #4
Here's the rest of it
Modifying the power steering pump. I rotated the return line fitting and drilled a new hole to bolt it in. I had to trim the pump a little for it to fit.
First startup...
After I confirmed that it was running correctly, I detached the harness and loomed it up...
Cutting the hole for the shifter...
Shot from underneath...
There it is. Once the interior was installed you could hardly tell.
Exhaust installed. The cat-back had to be shortened to fit.
Installing the new fuel pump...
The P13 ECU just barely fits behind this trim panel.
All that needs to be done is the a/c and clean up the engine. It runs great and is VERY strong.
Old 12-04-2006, 10:39 PM   #5
97SuperCivic's Avatar
Ride:  1997 Honda Civic
97SuperCivic is on a distinguished road
Hey, looks great, clean as hell. How many swaps have you done, and how long did that take?
97SuperCivic is offline   Reply With Quote
Old 12-04-2006, 11:44 PM   #6
Well I'm an expert in all Toyota swaps since I've been doing them for quite some time now. This was my first H22/Civic swap though. It took me about 4-5 days of work including rewiring the harness (not using an adapter harness) and whatnot.
-Doc
Old 12-05-2006, 02:04 AM   #7
Seany-izzle's Avatar
Seany-izzle is a jewel in the roughSeany-izzle is a jewel in the roughSeany-izzle is a jewel in the roughSeany-izzle is a jewel in the rough
awesome. what kind of mounts and axles did you use? Could you make a list of parts needed and stuff for reference purposes?
Seany-izzle is offline   Reply With Quote
Old 12-06-2006, 10:36 AM   #8
I beleive the kit was a place racing kit, and the axles were specific for the swap (provided by the customer). There are several lists out there if you look around, that's what I would do.
Where in VT are you from? I used to live in Newport.
-Doc
Old 12-06-2006, 10:48 AM   #9
Hon-daaaa
hazzardboy95's Avatar
Ride:  95 TEGGY
hazzardboy95 is on a distinguished road
nice swap, are you looking to hook it up anymore, or are you gonna run all motor
hazzardboy95 is offline   Reply With Quote
Old 12-06-2006, 08:45 PM   #10
-Doc
Oh no, not jewport haha. Im from brattleboro, southern vt. I go to school with a bunch of kids from up yonder.
Old 12-11-2006, 10:43 AM   #11
93 Del Sol
DelSlow89's Avatar
Ride:  93' Honda Del Sol
DelSlow89 is on a distinguished road
Hey I Got a 93 Del sol and im tryin to get a new engine for it. i was looking at the b16, b18 and b20 and im not sure which one would be the easiest to do?
DelSlow89 is offline   Reply With Quote
Old 12-11-2006, 11:05 AM   #12
HS Troll...And Mod
reikoshea's Avatar
Ride:  1999 Honda Accord
reikoshea has a reputation beyond reputereikoshea has a reputation beyond repute
reikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond repute
myspace
best to create a new thread for this question.
Sick swap, doc. Looks like it belongs there.
reikoshea is offline   Reply With Quote
Old 12-11-2006, 05:58 PM   #13
The Riced Sleeper
ThatGuy4life's Avatar
Ride:  2000 Si w/B18C5-R swap
ThatGuy4life has a brilliant futureThatGuy4life has a brilliant futureThatGuy4life has a brilliant futureThatGuy4life has a brilliant futureThatGuy4life has a brilliant futureThatGuy4life has a brilliant futureThatGuy4life has a brilliant futureThatGuy4life has a brilliant futureThatGuy4life has a brilliant future
myspace
Great work man
ThatGuy4life is offline   Reply With Quote
Old 12-12-2006, 07:11 AM   #14
93 Del Sol
DelSlow89's Avatar
Default Help!!!!!!
How do you start a Thread, I'm new to this Forum and I have no clue how to post or start a thread. By the way How hard is it to swap a b15 del sol for a b18 and c1 LSD tranny
Old 12-12-2006, 08:07 AM   #15
THE CHRIS
nice job!!
Old 01-10-2007, 09:14 AM   #16
blu
blu is on a distinguished road
How hard of a swap was it? How much did it cost? I'm dying to put an H in my 98' Civic EX. I've heard I would lose power steering and AC, was it hard preserving those things?
blu is offline   Reply With Quote
Old 01-10-2007, 01:36 PM   #17
I think including all the extra parts and labor it costed this customer around $2500, including the a/c and p/s and everything. That doesn't include the engine or mount kit.
-Doc
H22 / '99 Civic - Mystery of the missing RPM Output Wire Dr Tweak HYBRID -> EG-EK / DC 17 05-08-2008 03:14 PM
Engine Swaps 101 pissedoffsol Swap Articles 0 01-11-2004 06:54 PM
97 civic dx h22 swap bizzy Engine Building 1 09-21-2003 09:17 PM
Chassis Code VSMB16A2 General Tech and Maintenance 10 01-22-2003 04:32 PM
H22 Swap In Civic Coupe civicblazin101 HYBRID -> EG-EK / DC 1 01-09-2003 09:19 PM
© 2001-2010 HondaSwap.com
a SkeyMedia Network site
