KMS-fab
Ride: S13
i am looking into purchasing a H22 swapped civic hatch. i was wondering if there is anythign special i should look for as far as problems related to the swap, correct usage of parts, wiring, common things overlooked or misused/wired? also, what are the best ecu's for these cars? and what comes stock? i've serched for some of this stuff, but have failed in finding things. is a gsr ecu compatable and better? thanks fellas,
brett |
the CORRECT axles (many times people use cut axles),
"Our enemies are innovative and resourceful, and so are we. They never stop thinking about new ways to harm our country and our people, and neither do we." -The thought provoking George W. Bush |
Admin with a big stick
Ride: 2003 S2000
Many people do use chipped GSR ECUs for H22s without any problems.
KMS-fab
Ride: S13
GSR ecu is what? P72...yeah. they chip them for better performance i'd assume, and it takes the rev limiter higher, no? also, it would have to be OBD compatible with the motor, etc.? the correct axles as in the prelude axles or stock ones for a civic hatch? thanks
brett |
#6 |
90-93 Integra axles and 90-93 Accord Intermediate shaft should be used for ur hatch...
[/quote]Silverchild79 on Jun 6 2004, 10:59 PM And god forbid you should have to defend the country you benifit from...... |
#7 |
handling BLOWS
92 hatch, b18c block b16 head rsr GT-II exhaust, skunk2 valvetrain. skunk2 manifold <span style=\'font-size:14pt;line-height:100%\'><span style=\'color:red\'> Michael Moore...You've just been pwnd'</span></span> |
#9 |
i think the h22 is like 60 something lbs. heavier than the stock d series which is quite a bit optimum weight distribution as you probably know is 50/50 and with that h22 upfront your maybe looking at 70/30 im not sure correct me if im wrong ima dumbass.
![]() __________________
http://www.midwesthybrid.com |
#10 |
WRX Sellout
Ride: 2002 WRB Impreza WRX
Adding 70 pounds makes you go from a 50/50 (which most Hondas DON'T have) to a 70/30? Come on, we can do better than that.
Simply: Let's say you've got a 2500 pound car....1250 in the back, 1250 in the front. Add 70 pounds to the front, and you've got a 2570 car, with 1320 in the front. 1320/2570 = 51.3% So 51.3/48.7.....hardly a 70/30 split. __________________
This space left intentionally blank. |
#11 |
oops i wasnt trying to say hondas were 50/50 i was trying to say the added 70lbs is taking you further away from the 50/50 and thats part of the reason they handle shitty
#12 |
Ride: 06 Chevy Silverado
The handling isnt that bad, just get a good suspension with proper spring rates and you'll be fine. I have been in a 94 hatch cx with an h22 and it handled pretty well.
Ex 89 crx si,91 & 95 Civic owner. 06 Silverado RCSB 20's, 2/4" Belltech lowering kit, waiting for 2 more cylinders, 1.9 more liters, and 208 more hp engine swap. |
#13 |
to be honest with you, if you have the correct suspension you wont notice much at all. a friend of mine has a h22 in a 95 hb and taking a turn in a stock civic hatch or a h22 really wasnt that much different.
#14 |
WRX Sellout
The whole handling thing is a myth drummed up by the B-series guys that are jealous of all the torque that comes with the H22.
:P ![]() __________________
#15 | |
Ride: '92 Civic CX
Garage: 1992 CX Hatch > Current Money Pit Grave: R.I.P. 1995 Integra GSR R.I.P. 1990 DX Hatch R.I.P. 1990 CRX Si |
#16 | |
2003 EP3 Civic SI - Pretty Much Stock (for now) 1990 Eagle Talon TSI Turbo AWD 2005 Kawasaki ZX-6R - 10.58 ET at 137 MPH |
#17 |
WRX Sellout
Don't take ANYONE'S word on it except someone who's actually done the swap for themselves. "I once rode in a Civic with an H22 and it handled like shit" does NOT qualify.
#18 | |
![]() they ARE known to break axles though. Some h22a civics' axles last, some just breaks everytime you gun it. I guess it depends on the engine mounting and the type of engine mounts you use. definately ask the previous owner about the axles. You should take it to a shop and plug in the obd system to see if it was a clean and complete swap. Civic/Integra's weight distribution is like a 60/40 or somewhere near? It is NOT 50/50, I know s2000 and rx7 fd3s's are very close to 50/50, but thats because the engine and drivetrain sits behind the front wheels for it being RWD. I don't think it's possible for FF's to achieve a 50/50 unless you put a lot of weight in the back, which is just plain retarded. And you can always use the throttle, brake, and steering to transfer weight, if you know how to. 50/50 isn't always the optimum weight distribution, it definately makes a balanced handling car BUT it largely depends on the driver and what setup they're the most comfortable with. __________________
<a href=\'http://www.hondaswap.com/gallery/browse.php?album_id=521\' target=\'_blank\'>2.0L naturally aspirated goodness</a> Georgia Institute of Technology Class of 2004 |
#19 | |
there problem solved, next question please. __________________
<u><span style=\'font-family:Courier\'>Mind your own damn business, b*tch!!!!!</span></u> .3K Club (Yea Baby!!!) Check out my accord I finally took some pics!!! PM me to tell me what you think of it: <a href=\'http://www.hondaswap.com/gallery/browse.php?album_id=862\' target=\'_blank\'>http://www.hondaswap.com/gallery/browse.php?album_id=862</a> |
#21 | |
there problem solved, next question please. [/b][/quote] I wouldn't exactly agree that coil overs adjust weight distribution on a car. This post made no sense. Coil overs adjust height and handling in one way. As far as weight distribution i would have to say ![]() __________________
#22 |
WRX Sellout
Yes, they are known to break axles, both because of the added troque and the way the engine sits in the engine bay. This problem can be solved by getting some good aftermarket axles.
#23 | |
Member of the 20 nut club
optimal weight distribution for FWD is 60/40
optimal weight distribution for RWD is 50/50 not sure about AWD if your not autoXing, road coursing or trying to carve up twistie back roads the handling is fine.... if you are ![]() __________________
МОΛΏΝ ΛΑΒΈ |
| 88+ ECU Error Codes | pissedoffsol | Reference Materials | 1 | 05-19-2005 01:03 PM |
| civic coupe and hatch a/c system | methos713 | General Tech and Maintenance | 0 | 02-07-2004 02:48 AM |
| Decoding VIN Numbers | pissedoffsol | General Tech Articles | 0 | 01-11-2004 08:48 PM |
| All This Reference Material, And No Cel Code Chart | Slo86GT | Members' Lounge | 5 | 06-13-2003 10:31 AM |
| H22 Into My 91 Civic Hatch Dx? | uriba69 | HYBRID -> EG-EK / DC | 4 | 04-14-2003 11:53 AM |
