h22 trans & integ axle problems
Old 10-04-2004, 11:36 PM   #1
Rep Power: 0 Jdmdelsolguy2004 is off the scale
Send a message via Yahoo to Jdmdelsolguy2004
ok im having some big problems first im installing the motor in my 94 JDM del sol
now the first problem im having is that i bought two 93 integ axles with the accord
mid shaft and the integ driver side axle will not go in all of the way i was
wondering if the two axles were shorter then one another. the second problem is
the trans when it was out sitting on the ground would shift into all five gears and
reverse but now it will only shift into 4th and that's it can some one help me out
please
Jdmdelsolguy2004 is offline   Reply With Quote
Old 10-04-2004, 11:37 PM   #2
Rep Power: 51 Slammed90Lude is an unknown quantity at this point
Send a message via AIM to Slammed90Lude
if it would shift into all gear before but only 4th now i suspect the problem is in the routing of the shift cables
how tight is the kink in the cables? perhaps they're binding in their housing
Slammed90Lude is offline   Reply With Quote
Old 10-05-2004, 11:57 AM   #3
no if the shift linkage is un hooked you cant move the shift levers on the trans thats the problem
Old 10-05-2004, 12:03 PM   #4
ohhhhhhhhhhhh
Old 10-10-2004, 02:17 PM   #5
i fixed the trans problem but now i still having a problem with the cv axles not going all of the way in the trans on the passanger side and the other cv axle will not go all of the way into the mid shaft
Old 10-12-2004, 01:29 PM   #6
Rep Power: 20 b204dr is an unknown quantity at this point
Send a message via AIM to b204dr
the integ axels work most of the time but .. you might have bad teeth.. or some thing blocking .. maybe lube it up a little.. heh some thing like that.. i didnt have problems with my friends hatch
friction created heat which creates power=does this apply in the word of automotive
b204dr is offline   Reply With Quote
