So I just finished my H22A1 in 92 civic cx hatch swap and I am having some pretty major issues.
For starters i am throwing 2 codes. ELD and Vtec pressure sensor. Tried replacing the underhood fuse box and rewiring all engine grounds. Cleared the ecu and they came back right away. Thats the begining of the issues. From there it goes over to my violently fluctuating tach when the engine speed is not changing. The tach will just die or stay at 3000 rpm when i gun the gas. This doesnt seem to have anything to do with the fact the car idles at just under 2000 rpm. Tried setting the idle screw its tightened all the way down as far as it goes, and sticking my fingers in the 2 holes in the throttle body only seems to drop the idle a tiny bit. at this higher rpm idle the timing seems to be almost dead on 15 degrees btdc. One last thing if that wasnt enough... The car vibrates like a b***h. But the vibrating seems to stop when i turn left but not right. Oh and I think the axles are binding when I hit bumps but I'm not sure i've never had to experience that before. The car is stock springs by the way. I think thats all right now..lol It's in pretty rough shape... i need the idle down and the vibrating to be less like when i turn left so my gf will actually ride in the car with me... Please someone help! |
#3 | ||
Ride: 1992 H22A Accord EX
maybe the motor mounts are installed incorrectly, or maybe you torqued them in the wrong order. possibly, one of the mounts could even be broken. as far as the tach, it could be a distributor problem, ignitor i think can cause that problem. for the idle, is the throttle cable opening the throttle body at rest?
I think i narrowed the idle issue down to throttle body gasket.
All the CEL's are gone now except the 20. The Distributor was brand new so i hope it isn't the igniter... What order do you reccomend torqueing the mounts in? I Am getting a new tranny as the one that came with the swap was shot so I will be pulling it anyways. Gonna do the TB gasket at the same time to try and tame the idle. Anyone that has done the h22a in the EG chassis... Do you have issues with the axles actually staying in the tranny? I can't get the snap rings to set in place and its frustraing the **** out of me. is there something different about the canadian integra axles vs. the american. I am running the 90-93 teg axles with 91 accord half shaft. Please help! |
| H22a into EG hatch | gettocrx | Civic and del Sol - EG and EK | 4 | 02-11-2009 09:15 PM |
| OBD2 h22a type S in my OBD1 H22a hatch | Zarboz | ECU's, Electronics, and Tuning | 2 | 11-22-2008 11:27 PM |
| Final help installing JDM h22a in civic hatch | AEIperformance.com 92egH22 | HYBRID -> EG-EK / DC | 34 | 10-01-2008 02:07 AM |
| H22a 95 Civic Si Hatch | onefastcivic | HYBRID -> EG-EK / DC | 9 | 03-26-2003 11:19 AM |
| H22a 92-95 Into A 92 Civic Cx Hatch | Speed_induced_hatch | HYBRID -> EG-EK / DC | 3 | 03-14-2003 01:19 PM |
