H2B worth it in a eg?
Old 02-02-2008, 09:36 AM   #1
Rep Power: 0 turboedsupe is on a distinguished road
Default H2B worth it in a eg?
Im swapping a h22 into my eg and was looking at the h2b kit. I read you can use b-series linkage, clutch, and axles. Someone also said the gearing on a gsr tranny would make it alot quicker but when would it top out? Is this the only way to really get around breaking axles on a h22 swapped car? I seen some company called evolution made them just wondering if there mounts are even worth a shit?
turboedsupe is offline   Reply With Quote
Old 02-02-2008, 09:38 AM   #2
eBay Motors: H2B kit H22 to b16 b18 civic 92-95 integra DC2 mount (item 250208663026 end time Feb-21-08 01:05:58 PST)
Old 02-02-2008, 09:50 AM   #3
nootrac22's Avatar
Ride:  daily driver working on 92 prelude 4ws
Rep Power: 215 nootrac22 has a reputation beyond reputenootrac22 has a reputation beyond repute
nootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond repute
Send a message via Yahoo to nootrac22 Send a message via Skype™ to nootrac22
Fatboy Raceworks Transmission Gear Ratio Calculator - Honda/Acura & More. I can't speak from personal use, but I've heard good things about the adapters.
nootrac22 is offline   Reply With Quote
Old 02-02-2008, 11:09 AM   #4
übber ɐɾuıu etarip
Z6CRX's Avatar
Ride:  1995 BMW 318ti, 1985 Honda VF500F(now legal)
Rep Power: 73 Z6CRX has a reputation beyond repute
Z6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond repute
Send a message via AIM to Z6CRX Send a message via Yahoo to Z6CRX myspace  FaceBook
Ha, this stuff makes my kit look even more of a deal.
Best thing to do is to look around people that actually swapped them and, IE build threads, and see how everything went and what kit they used. I can't name any off hand.
I bought mine used from a guy he didn't have any problem, then I got it in my car, had too many issues my cars wiring and my old brakes had all went to hell from sitting waiting for a good swap.
Originally Posted by Celerity View Post
No one hates anyone around here more than people hate Celerity. He's an asshole.
Z6CRX is offline   Reply With Quote
Old 02-03-2008, 06:25 PM   #5
Ride:  94 Black Del sol,B16A2 sir, I/H/E/T..... rip built ls-v
Rep Power: 6 Mike_995 is on a distinguished road
Ok so the gsr tranny will top out at 166 mph if you have 205/40/17's which is quite a high speed. Heres the site Fatboy Raceworks Transmission Gear Ratio Calculator - Honda/Acura & More hahaha ooops nootrac, didnt even noticed u used the same calc.
As far as that H2B kit, i think its a waste of money, if you already have a B-series motor in your car why not put the 1200 $ or more into the b engine instead of buying the h2b kit. You could do up a nice b20 vtec for cheaper than the kit and the h22. And it would be a helluva lot faster aswell.
Mike_995 is offline   Reply With Quote
Old 02-04-2008, 01:10 AM   #6
übber ɐɾuıu etarip
Z6CRX's Avatar
The only problem is you have to build the B20, B18, B16 get to the point of a stock H22. H series has more potential from displacement and a better starting point.
Screw just doing the B20 Vtec, if you want something fast turbo it. Almost any proper tuned turbo Honda can haul some ass. It all depends on what your looking at it and try to calculate the cost to what you'll get and what you're looking for.
Old 02-04-2008, 09:49 AM   #7
Yea I was originally gonna go with turbo, but I figure for now ill go ls vtec, then this winter build up my turbo. I dunno man, the h22 only has 200 hp, b20 vtec will easily get 200 hp without even building the motor. But I agree with the turbo idea, build the bottom end, slap a turbo on it and youll have a killer ride.
Old 02-04-2008, 10:39 AM   #8
übber ɐɾuıu etarip
Z6CRX's Avatar
You need some compression to get those numbers with a B20, replacing pistons and putting on a new head + modifying it to work would still justify as building. Unless you buy a newer B20Z block which you'll end up spending more and still not have high compression. Then you need to tune it. It is also recommenced to build up the bottom for some revs since the engine normally does rev like it would with the new head.
You already have a good base torque line with the H and it is straight out stock. I have no problem with either engine. The one downside is the aftermarket support is not as diverse for the H as it is for the B.
Personally the next thing i would build again would be a nice turbo D..
Old 02-04-2008, 02:29 PM   #9
Well my hatch is stock with a d15 the only reason i was thinking about this swap is cause i want the h22 powerplant i just dont want to snap axles left and right. I heard doing this allows you to use b series axles and such so there not at a akward angle like that on a h22 swap. I was just wodering if anyone has a h22 swap using a h22 tranny and doesnt break axles like crazy
Old 02-04-2008, 03:29 PM   #10
I dunno man, your going to snap axels anyway, especially if you go turbo. One thing about the h22 is you are going to have to get a slim rad fan, and if you have ac you will have to loose it. Its definitly a little tougher swap than a b-series swap. You should be fine if you order mounts from a reputable company such as hasport. You wouldnt really need the h2b kit, you could just get the entire swap.
Old 02-04-2008, 04:34 PM   #11
übber ɐɾuıu etarip
Z6CRX's Avatar
I'm not sure if the H22 swap alone much less the H2B will require a slim fan on either case, I didn't need one in my rex, and theres gobs more room in an 92+ model. But on 88-91 civics you need to cowl the hood or modify it. 92-95 you can just prop the hood up on the back with washers.
Hell if your feeling adventurous go H2D, but at least get an EX tranny because the adapter plate kits are for OEM placement of the transmission, gearing, and more cost effective when it comes to the transmission.
If its your first time swapping I'd say go either B or turbo. Unless you have someone around you that has been doing this before.
Old 02-04-2008, 08:40 PM   #12
Never swapped a honda but ive worked on cars and everything else. I have went through all tech articles and the only difference in the swap is cuttin a mount and hole for the linkage. Im getting a different radiator fan setup anyways to make sure it stays cool down here in az. Im also goin to run a/c i have talked to people that build the mount for my stock d15 compressor to work. I just want to have a nice quick DD that wont break if i try to launch it. Maybe ill just break down and buy some DSS stage 2's
Old 05-26-2008, 05:52 PM   #13
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
Rep Power: 189 BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
myspace
Check the dates on stuff before you post dude...this thread is almost 4 months old...
PSN Network ID: BrutalB83
Old 05-26-2008, 08:42 PM   #14
|Chaz|'s Avatar
Ride:  92' EG Sedan
Rep Power: 156 |Chaz| has a reputation beyond repute
|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute
Send a message via AIM to |Chaz| Send a message via MSN to |Chaz| Send a message via Yahoo to |Chaz|
Why is Brutal's post the only one here now? Is there some post that got deleted or something?
XBL Gamertag = i1Chad1i
i (space here)Chaz(space here)i
|Chaz| is offline   Reply With Quote
Old 05-26-2008, 09:10 PM   #15
The Trisexual
92civicb18b1's Avatar
Ride:  2007 Civic, 1995 Jeep Grand Cherokee
Rep Power: 122 92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of
Send a message via AIM to 92civicb18b1 Send a message via Yahoo to 92civicb18b1
what, you're the 14th post.
DO NOT PM ME WITH TECH QUESTIONS!!!
Current Rides
1992 Chevy S-10 Ext. Cab
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned,
253whp
1994 Civic VX Hatch, 1992 b18a1 swap
1993 Civic CX Hatch, 2000 B18b1
92civicb18b1 is offline   Reply With Quote
Old 05-27-2008, 01:29 AM   #16
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Rep Power: 43 LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
lol @ deleted post.
eg hatch (jdm b16) sold
1999 Yamaha YZF R6 (modded)
http://hondaswap.com/engine-building...ow-pics-102486 sold
LS_VTEC is offline   Reply With Quote
Old 05-27-2008, 03:32 PM   #17
Brutal Moderator
BrutalB83's Avatar
myspace
It must have gotten deleted. You can delete your own posts if you want...
Old 05-27-2008, 07:29 PM   #18
I didnt delete it...
Old 05-27-2008, 08:07 PM   #19
Brutal Moderator
BrutalB83's Avatar
myspace
No one said you deleted anything. Somebody else posted in here after it had been dead for three months. I told them "hey, check the dates on stuff before you hit reply from now on." That post is now gone, so they must have come back and deleted it. Que pasa?
Old 05-30-2008, 11:28 PM   #20
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Rep Power: 288 Calesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud of
The original poster deleted it:
05-26-2008, 04:45 PM
F20EG
This message has been deleted by F20EG.
"i just completed the swap a few weeks ago im running a f20b motor all i can say is this shit is amazing the gear ratio is so short its crazy this is the best way to get acceleration out of a h22 im running the bisimoto kit with a b16 tranny with a quafe lsd adapter"
Is the H22A swap worth it in an Accord? I say yes HONDAPITSTOP HYBRID -> BA-BB /CA-CD 20 03-28-2008 01:02 PM
Whats it worth ?? boostedf22 Engine Building 3 08-22-2007 12:53 AM
is it worth installing flywheel? hatchbros 93 General Tech and Maintenance 1 07-30-2007 11:19 PM
Suspension Upgrades: What is worth the $ for confusatron Wheels / Suspension / Tires / Brakes 49 10-10-2005 08:50 AM
Is it worth it to build up a B17A1? Mighty Engine Building 6 03-16-2004 10:24 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
