Head For D15b2
Old 06-02-2003, 12:08 PM   #1
adamparker is off the scale
Hi!!
I want to do head swap to my 92 Honda Civic with 1.5l D15B2. I can't do all engine swap .
I am doing some 400 m races and I don't want move up to 1.6l engine category.
I was thinking off going extreme and swaping some 1.6l VTEC head complete with
intake manifold, wiring and ECU. Can anyone tell me which head will fit my engine
block?? I am ready to do some extra work to conect oil supply to VTEC valve and
maybe drilling bigger dowel holes.
THNX
Adam
adamparker is offline   Reply With Quote
Old 06-02-2003, 01:28 PM   #2
MaaseyRacer is an unknown quantity at this point
Send a message via AIM to MaaseyRacer
the d16z6 head will fit your block nicely, almost any d series head will fit. the best combo for you would probably be a d16z6 head and a d16y8 intake manifold.
MaaseyRacer is offline   Reply With Quote
Old 06-02-2003, 01:39 PM   #3
Member of the 20 nut club
E_SolSi's Avatar
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
the D16Z6 head will fit directly on your block fine ... you dont need to drill anything... just remove the oil jet in the block ... the head has its own... the Y8 intake manifold is the way to go... get an LS integra 60mm TB too.... drop in some high compression pistons... and a cam
(ever consider resleeving to a larger bore? the block will still say its a 1.5 )
also look into getting an EX/Si tranny with an LSD
Old 06-03-2003, 11:44 PM   #4
Thanx!!
I have just 2 questions. Do I have to run oil supply to VTEC valve ( like integra 1.8 swap LS to GSR ) ?
And what is - oil jet - in block ?? My english is litle too poor to understand it.
BEST REGARDS
Adam
Old 06-04-2003, 02:42 AM   #5
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
pissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to behold
this should help:
http://www.geocities.com/chipman_13/mini-me-parts.html
Head Gasket Repair (o)(o) General Tech and Maintenance 24 10-01-2007 11:09 PM
B18A1 Can I add VTEC? psychochicken HYBRID -> ED-EF / DA 9 01-19-2004 09:31 PM
ls/vtec werd KWJaY Engine Building 11 09-10-2003 04:39 PM
I think I found it! B-18Hatch Members' Lounge 8 08-07-2003 11:12 PM
LS-VTEC/CR- VTEC Info pissedoffsol General Tech Articles 1 11-10-2002 03:19 AM
