header length ?
Old 06-12-2005, 06:41 PM   #1
Rep Power: 11 deity is off the scale
does anyone know much difference in length is there between the gsr header stock. and the b18b header stock?
i ask this because im going to have an exhaust stop extend my header to mate up to my catback and i need a length.
deity is offline   Reply With Quote
Old 06-12-2005, 07:47 PM   #2
Rep Power: 13 sihatchback_RL is off the scale
B18B won't fit, B16 is what you need.
1991 Honda CRX Si, JDM B18C GSR Swap, AEBS Manifold, CTR Pistons, DPR ITR Stage 5 Head, Skunk2 stage 2 Cams, Skunk2 cam gears, AEM V2, ANR Header, Greddy E-Manage, ACT 6 puck clutch, AEM fuel rail, Eagle Rods, Type R tranny, Enjo axles, Runs 12.8 ALL MOTOR!
sihatchback_RL is offline   Reply With Quote
Old 06-12-2005, 08:10 PM   #3
FüK-VTEC
civicious's Avatar
Ride:  07 Nissan Frontier, 90 CRX Si, 06 ZX6R racebike, chopped-out 02 Yamaha V-Star
Rep Power: 189 civicious has a reputation beyond reputecivicious has a reputation beyond repute
civicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond repute
Send a message via AIM to civicious myspace
Not if he's got a 1.8....a B16 header is too short (valve cover to oilpan) because a B16 block is around 8mm shorter than a 1.8 block.
I dunno the exact length...it's a couplea inches. Just drive up there with open header and let the muffler shop put in a piece of pipe whatever length it needs to be.
CMRA #265
http://www.myspace.com/civicious
AIM: greyfades
civicious is offline   Reply With Quote
Old 06-13-2005, 01:32 AM   #4
WRONG, a B16 does fit, Numerous of my friends with GSR swap in EG has B16 Unit, Even i have the setup when i first swapped it in.
Old 06-13-2005, 11:12 PM   #5
Rep Power: 10 thr33niL is off the scale
Originally posted by sihatchback_RL+Jun 12 2005, 10:32 PM--><div class='quotetop'>QUOTE(sihatchback_ RL @ Jun 12 2005, 10:32 PM)</div><div class='quotemain'><!--QuoteBegin-civicious@Jun 12 2005, 07:10 PM
[/b][/quote]
SERIOUS??!?! You mean all I have to get for my 95 Civ Coupe and GSR motor is a B16 header and it would mate to my civic cat and exhaust?
:::crossing fingers::::
thr33niL is offline   Reply With Quote
Old 06-13-2005, 11:57 PM   #6
Ride:  93 del Sol Gas sipper
Rep Power: 101 asmallsol is a jewel in the roughasmallsol is a jewel in the roughasmallsol is a jewel in the rough
I am almost positive that it will, and currently am looking for one locally so I can finish my swap.
Collin
Material Science and Engineering
Michigan Technological University
Old 06-14-2005, 01:00 AM   #7
Originally posted by asmallsol+Jun 13 2005, 08:57 PM--><div class='quotetop'>QUOTE(asmallsol @ Jun 13 2005, 08:57 PM)</div><div class='quotemain'><!--QuoteBegin-thr33niL@Jun 13 2005, 11:12 PM
[/b][/quote]
Keep us up to date on it. I have been messing with my exhaust for 3 weeks trying to avoid a muffler shop. I am :::this::: close to just getting a GSR header and taking her to get fitted.
Old 06-14-2005, 01:24 AM   #8
For my del sol, My exhaust wasn't the best (muffler shop custom job, crush bent pipes, fat can thermal muffler and my GSR manifold was a few inches short. So instead of going to the muffler shop, I cut the muffler a few inches after the cat flange, and then stuck a slip joint pipe to make up the diffrence.
Here is the outcome..
Collin
Old 06-14-2005, 02:26 AM   #9
Trust me i put my two cents on the flop that the B16 header will fit. I have swap over numerous GSR in EGs and just took off a header from a blown B16 and slap it on. ANOTHER thing is that you can't use a GSR cat. the stock civic will bolt, with little manly force.
Old 06-30-2005, 01:49 AM   #10
sihatch, you 100% freakin right.
I took your advice bro and bought a 99-00SI/94-97DelSol DC header and it fit perfect!
Thanks a million man. So much cleaner than chopped, muffler shop type fixes.
So this is double confirmation.. Anyone swaping a B18C into an EG civic can use a DelSol/SI header to span the notorious gap between the collector and cat.
NICE
Old 06-30-2005, 09:35 PM   #11
Rep Power: 9 younglord94 is an unknown quantity at this point
is it the same in an ek civic i'm putting a b18b1 in my hatch
younglord94 is offline   Reply With Quote
Old 07-01-2005, 03:27 PM   #12
thr33l, on the b16 header, is there a O2 bung on the header portion. Because if you use your civic cat, there is no O2 bung on it.
Collin
Old 07-02-2005, 12:41 AM   #13
Yeah on the B16 header I got (DC) there is an o2 bung down by the collector.
Old 07-02-2005, 12:44 AM   #14
I really cant say for positive but since the header I bought is fitted for 00-01 SI's, if I had a guess, I would say yes.
Old 07-02-2005, 06:32 AM   #15
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
B16A header will fit, it's just real tight. It should have an o2 bung by the collector no matter what the year it is for, as they all (US models) have one there, just the obd II ones have one on the cat too.
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 07-02-2005, 10:29 AM   #16
The Trisexual
92civicb18b1's Avatar
Ride:  2007 Civic, 1995 Jeep Grand Cherokee
Rep Power: 122 92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of
Send a message via AIM to 92civicb18b1 Send a message via Yahoo to 92civicb18b1
my obd1 92 b18a1 header only had one in the middle of where the heat shield would be. maybe 7-8" from the head. There wasn't one furthur down. That was a pain in the ass.
DO NOT PM ME WITH TECH QUESTIONS!!!
Current Rides
1992 Chevy S-10 Ext. Cab
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned,
253whp
1994 Civic VX Hatch, 1992 b18a1 swap
1993 Civic CX Hatch, 2000 B18b1
92civicb18b1 is offline   Reply With Quote
Old 07-02-2005, 10:32 AM   #17
learning in progress
formby's Avatar
Rep Power: 93 formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
it will fit i used an oem b16 header on my lsv....for almost 6 months
http://pandora.com/
