help me please
Old 10-22-2004, 04:55 PM   #1
Rep Power: 16 mrnice1058 is off the scale
Send a message via AIM to mrnice1058
ok i finally got my check engine off it was a code 14 got it fixed i didn't move the wire over on the ecu but here is my last problem...i hope there is a sound coming from my engine and i can't tell what it is it is not pinging and not banging it sounds like something is rubbing somewhere but i can't find anything rubbing like the alt or the ac i am not sure what it is if you don't know my story here is my deal i had a busted rod and i replaced all of them, so i am not sure if it is a cam but i took the valve cover off and nothing looks bad to me and i don't see anything broken in there. i was told it was my ac so i took the belt off and i am still getting the sound please help me i want to get the civic on the road just for a test run please help me out tell me where to look and what to look at thanks guys
started but running pretty rought have any advise pm me and let me know!!
mrnice1058 is offline   Reply With Quote
Old 10-24-2004, 07:07 AM   #2
Rep Power: 15 93cxhatch is off the scale
Send a message via AIM to 93cxhatch
it's probably your timing belt rubbing on one of the plastic covers, I had that problem on one of my old motors. Just loosend up the covers a little and see if it stops making a rubbing noise.
93cxhatch is offline   Reply With Quote
Old 10-24-2004, 10:42 AM   #3
Rep Power: 13 twisted civic is an unknown quantity at this point
timing belt too tight? that will make a rotational rubbing type sound. back the tensioner off a little.
twisted civic is offline   Reply With Quote
Old 10-24-2004, 02:27 PM   #4
thanks man that is what i was thinking if i get it to work out today i will let you guys know thanks
