I have finished wiring up my 99 b16 with a 97 ex harness (motor not in car). I have all sensors and harness clips identified except one. The sensor is not on the engine itself, but the harness is located under the intake manifold. It a one-wire harness with blue/red color. I am looking for some input on this harness or rather the sensor it goes to.
http://www.autoserve.8m.com/OBD2ab1.html According to this site, it the "ACS", but what is that. |
According to that site the pinout is A27 which is the Engine Coolant Blower Motor Switch on OBDII.
However, I list that sensor as a Yel/Grn wire from sensor to ECU. __________________
Perfect Power Canada - National Distributor <a href=\'http://www.perfectpower.ca\' target=\'_blank\'>http://www.perfectpower.ca</a> |
RETIRED
its for the A/c system. more commonly called the A/C Request Input. it raises/adjusts idle approprately when the a/c is kicked on.
#7 |
FüK-VTEC
Ride: 07 Nissan Frontier, 90 CRX Si, 06 ZX6R racebike, chopped-out 02 Yamaha V-Star
i've got that blue/red plug plugged into my knock sensor, theres nothin else back there that it would plug into...
course it dont matter cuz i have a p28 (p28 = no knock sensor) i sure did think thta was the knock sensor thogh.... |
#8 |
Knock sensor is red/blue.
The EX (our Canadian Si right?) uses a knock sensor. __________________
