Helping a friend with D16Y8 to D15B swap
Old 06-22-2006, 10:46 AM   #1
dr.fowler is an unknown quantity at this point
Default Helping a friend with D16Y8 to D15B swap
Hey all, I'm helping a friend figure out his swap, and I'm not sure on some of his questions. He has a 98 EX, ordered a single cam vtec replacement and got a dual stage vtec d15b. I know about swapping over the crank angle sensor and the oil pressure sensor, but I'm not sure about getting the vtec to work. Is there a way to make just the hi-lift vtec work, or does he need a p08 ecu to have any vtec? Also, isn't the P08 ecu obd1? Is there a direct plug in ECU that will run that system on OBD2? I searched but didn't find anything real helpful, so if you know of another thread, links would be great help!!
dr.fowler is offline   Reply With Quote
Old 05-23-2007, 12:49 PM   #2
dznutz157 is on a distinguished road
im in the exact same boat only with a 96 ex and a 98 d15b vtec... i believe you can simply wire up the one vtec solenoid and leave the vtec E one disconnected
dznutz157 is offline   Reply With Quote
Old 05-23-2007, 09:23 PM   #3
killercannible will become famous soon enough
not connecting one of the vtec solenoids won't hurt anything. Hook up the vtec solenoid, not the vtec-e, and run a p2e obd2 ecu.
killercannible is offline   Reply With Quote
Old 05-23-2007, 09:24 PM   #4
i have the p2p ecu... should still work
Old 05-24-2007, 12:50 PM   #5
I think i meant the p2p, whatever one comes stock on the obd2a civic ex's.
Old 05-28-2007, 05:45 PM   #6
Lick my nuts.
93civicracer's Avatar
Ride:  '90 Accord DX, '93 Civic JDM D15B
93civicracer is a jewel in the rough93civicracer is a jewel in the rough93civicracer is a jewel in the rough93civicracer is a jewel in the rough
Send a message via MSN to 93civicracer
Yea you might want to lose the vtec e, from what I've gathered, it's only for fuel economy and slows you down some.
93civicracer is offline   Reply With Quote
Old 05-28-2007, 10:07 PM   #7
Lick my nuts.
I think that's kind of a pointless swap unless there's something wrong with the y8. Aren't the y8 and d15b both sohc vtec that produce about the same power?
Old 05-29-2007, 08:28 AM   #8
JDM EK
Ride:  97 civic with a jdm 3 stage Vtec D15B
whudupfoo is on a distinguished road
Send a message via MSN to whudupfoo
i just did the exact same swap in my 97 EX, i hooked up the green and yellow wire, is that the right one? also my motor wont idle steady. it jumps between one and two... does anyone know why? i noticed that there is a place to hook up a map sensor on the d15b intake manifold but i put my y8 throttle body on it. was that a mistake? the throttle body that came on the manifold was stuck and i couldnt fix it. would i be better off putting the whole y8 manfold on my d15?
whudupfoo is offline   Reply With Quote
FS: Everything d16y8 related drunkNun Parts: For Sale/Trade/Wanted 16 07-17-2006 04:40 PM
Need help with JDM D15B Swap.. integrafreek HYBRID -> EG-EK / DC 5 04-11-2005 02:01 AM
Help My Poor Friend Figure Out His B16 Swap. Accordturbo94 HYBRID -> EG-EK / DC 11 09-04-2004 02:43 AM
D16Y8 or D15B test_drive General Tech and Maintenance 11 07-30-2004 05:07 AM
Wtb 94-up Gsr(b18c1) Complete Swap For My Friend hondacivicvtec99 Parts: For Sale/Trade/Wanted 2 02-11-2003 01:43 PM
