how do i do auto to manual swap
Old 11-18-2003, 06:20 PM   #1
Rep Power: 0 94civicexand92hatch is off the scale
i have done all of the bolt up work, all i need to do is put a master cylinder in. i have actually taken out the body mount for the tranny, and mounted my own mount. i need to know if the auto computer will work on manual. any info you guys have would be nice. thank you
94civicexand92hatch is offline   Reply With Quote
Old 11-18-2003, 06:38 PM   #2
Rep Power: 25 MXDesa will become famous soon enoughMXDesa will become famous soon enough
Send a message via AIM to MXDesa
The auto computer will work. Ur probably going to have to use it anywayz because when doing this swap, it is required to change the intake manifold and a few sensors on it as well. Im not sure which ones but u could just change the whole thing. If you use a manual computer on a engine with a IM from an auto, it will NOT start. Make sure u get the wiring correct.
2003 EP3 Civic SI - Pretty Much Stock (for now)
1990 Eagle Talon TSI Turbo AWD
2005 Kawasaki ZX-6R - 10.58 ET at 137 MPH
MXDesa is offline   Reply With Quote
Old 11-19-2003, 05:08 PM   #3
i have the d16z6 engine already in the car and the computer goes to it but will it work with an manual tranny the ecu is for an auto
.just need to know what kind of wiring needs done or where else can i find out,,thanks!
Old 11-24-2003, 11:43 PM   #4
Rep Power: 0 h22civic92 is off the scale
you have to jumper a few connections in the harness that used to plug up to the auto shifter assy, for reverse lights, nuetral safety switch, and also a solonoid has to be jumped so you can remove the key from the ignition... its not too bad.
h22civic92 is offline   Reply With Quote
Auto VS Manual ECU reckedracing ECU's, Electronics, and Tuning 6 06-14-2004 06:48 PM
auto to manual swap wiring??? thegreat1310 HYBRID -> ED-EF / DA 2 01-19-2004 06:29 PM
Auto To Manual dustylax ECU's, Electronics, and Tuning 1 05-14-2003 02:00 PM
Auto To Manual Swap civicdude98 Engine Building 4 03-06-2003 01:51 PM
