how do you change TPS sensors??
Old 02-17-2005, 01:06 PM   #1
Rep Power: 15 DelSlo is off the scale
how do you change TPS sensors, mine are rivveted on my d15 and my d 16 throttle bodies.
im lost cause in "pills" write up on testing tps he says rotate it till you see 0.5 V. well how the heck do you rotate it? and how do you change it
93' Del Sol
2000 B16A2 swap.
garrett T3/T4 (.48/.60)
Weapons of choice.. Innovate LC1 and Crome Pro
Faze EL Engine management guages.
DelSlo is offline   Reply With Quote
Old 02-19-2005, 06:17 PM   #2
Rep Power: 10 gsrpoweredcivic is off the scale
Send a message via AIM to gsrpoweredcivic
theyre not rivets they are screws. take a pair of vice grips and turn them they will come off and then you replace them with regular screws and then adjust it
gsrpoweredcivic is offline   Reply With Quote
Old 02-19-2005, 07:47 PM   #3
Ride:  '92 Civic CX
Rep Power: 39 D See 2 is an unknown quantity at this point
Send a message via AIM to D See 2
exactly, just try to get some vice grips on there. If you can't, grind the high part off and it will let you pull the sensor off. Then you will def. be able to get vice grips on there. pull the rest of the stud out and replace with screws.
Garage:
1992 CX Hatch > Current Money Pit
Grave:
R.I.P. 1995 Integra GSR
R.I.P. 1990 DX Hatch
R.I.P. 1990 CRX Si
D See 2 is offline   Reply With Quote
Old 02-19-2005, 09:48 PM   #4
Rep Power: 18 TWISTEDIMAGE is off the scale
Send a message via Yahoo to TWISTEDIMAGE
i always had luck with dikes (not the ones on the street the tool)
they grab it better
hi
TWISTEDIMAGE is offline   Reply With Quote
Old 02-20-2005, 12:15 AM   #5
cool thanx guys!
93' Del Sol
2000 B16A2 swap.
Old 02-20-2005, 01:49 AM   #6
Ride:  RX5.7 Civic LS and Teg Ls
Rep Power: 25 civiclxb16 will become famous soon enough
Send a message via AIM to civiclxb16 Send a message via Yahoo to civiclxb16 myspace
i used a hammer and a chisel tapped them lightly and she came right off
Check Out My Car Club
www.HighRevCustoms.com
and join the forums
this is what happens when you are bored out your mind!!:|
my current baby http://i114.photobucket.com/albums/n.../myspacefc.jpg
civiclxb16 is offline   Reply With Quote
