Improving the front brake system in civic EX coupe 96 ??!!
Old 10-31-2008, 10:00 PM   #1
Rep Power: 7 loverboy is on a distinguished road
Default Improving the front brake system in civic EX coupe 96 ??!!
Hello guys !
I want to improve my braking system in my civic EX 96 D16Y8 engine - due to a planned B18C5 swap.
I thought about starting with the front discs and swap them to a wildwood brake kit.
Any one can tell me if my OEM discs is 240mm diam ?
What is your opinions about the kit Dynalite Big Brake Front Hat Kits (Dynalite Big Brake Front Hat Kits)?
Which minimum wheel diam do i need for this kit ?
Thanks !!
loverboy is offline   Reply With Quote
Old 10-31-2008, 11:14 PM   #2
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 150 K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin
Just upgrade the pads.
Stock brakes should be 262mm rotors on that car.
A "hat" kit is just that center piece/hub. If you want Wilwood brakes look into Fastbrakes.com setups. The size wheel you need depends on what size rotors/calipers you get.
1988 Honda Civic Standard-more mods than I want to list
1992 Honda Accord LX
1996 Toyota Avalon-Spun bearing, for sale.
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
Old 11-01-2008, 12:30 AM   #3
|Chaz|'s Avatar
Ride:  92' EG Sedan
Rep Power: 156 |Chaz| has a reputation beyond repute
|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute
Send a message via AIM to |Chaz| Send a message via MSN to |Chaz| Send a message via Yahoo to |Chaz|
Just get some Hawk HPS brake pads and some brembo blanks. It'll make a huuuuuuuge difference. You'll need better tires though, otherwise you're just going to be locking up the front tires all the time.
XBL Gamertag = i1Chad1i
i (space here)Chaz(space here)i
|Chaz| is offline   Reply With Quote
Old 11-01-2008, 12:43 AM   #4
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 334 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
in my mirage i upgraded from stock 256mm single pot to evo3 276mm dual pot up front, and from drum to gvr4 260mm single pot in the back. i also added the 3kgtvr4 MC. i can lock up all four tires now heh. brembo blank rotors and hawk HPS pads all the way around.
depends on what YOU are doing. if you arent autocrossing go as big as you can but remember the bigger the brakes the bigger the wheels need to be. i cant fit anything smaller than 15" wheels up front, and i cannot fit 16" steelies. SS lines will do a world of good as well for a stock brake size.
im planning for a few hundred HP and AWD though, and my brake upgrade with 4x114 hubs cost me ~800 bucks.
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the little Evo5.
"If you don't like what I've done with my car, I will gladly refund all the money you put into it."
Old 11-01-2008, 12:49 AM   #5
K2e2vin's Avatar
Bigger brakes are only needed if you're having fading issues(ie road course).
RIP
Old 11-01-2008, 11:10 AM   #6
Thanks Chaz but i already replaced a year ago to Hawk HPS.
Beside that i have a 16" wheels with realy good tires - goodyear eagle F1.
Steel i want to improve my brake system and the wilwood seems like a realy good kit.
So i need your opinipns on there kits Please !
(If anyone have an idea where can i buy a kit in Manhattan it will helpfull too)
Do anyone can confirm that in my car the size of the disc is 260mm and not 240mm?
Old 11-01-2008, 11:49 AM   #7
|Chaz|'s Avatar
Ride:  92' EG Sedan
Just put some NSX brakes on it lol
NSX calipers install how-to - Team Integra
Improving the suspension system civic EK 96 - Bilstein Or TEIN??? loverboy HYBRID -> EG-EK / DC 8 10-22-2008 10:37 AM
DA, or DC brake system change. '91 rex SI Andrew Civic and CRX - EF 9 07-26-2006 04:36 PM
brake system volume? seanjuan Wheels / Suspension / Tires / Brakes 25 06-30-2005 04:36 PM
civic coupe and hatch a/c system methos713 General Tech and Maintenance 0 02-07-2004 02:48 AM
Brake System Bl6CRX General Tech and Maintenance 0 07-28-2003 06:53 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
