installing d16z6
Old 07-15-2004, 09:41 PM   #1
Rep Power: 16 wisemansoji is off the scale
I put a d16z6 into a 93 sedan civic, and the engine is throwing map sensor codes, o2 sensor codes and a bunch of others. The car was not pre wired so I ran wires for the vtec. Any was the when I use the 1.6L map sensor the cars idle bounces between 1500-2500. I have to use the 1.5L mapsensor which is on th ecars body and the idle is constant but really high.
I found out this is happening becuase theres three more wires the cars bodies harness is missing which are right by the vtec wires,
its missing pinout D21 -SG1 D17 Map( explains why) and D19- VCC1
My question what do the D21 SG1 and D19 VCC1 stand for, and also should I expectg to find other wires that aren't pre wired for installing a d16z6 ina 93 sedan.
wisemansoji is offline   Reply With Quote
Old 07-16-2004, 01:13 AM   #2
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
All three of those are for you MAP sensor.
What 93 Sedan?, not that it really matters, it shouldn't be missing those wires anyway.
MAP - YEL/RED --|| -- YEL/GRN -- ECU at D19
""" - WHT -------|| -- PNK/WHT -- ECU at D17
""" - GRN/WHT --|| -- GRN/BLU -- ECU at D21
|| indicates the engine bay canon plug.
There's no way they are missing. It's not a special sensor that changed based on model, maybe you're looking at it backwards.
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 07-16-2004, 03:23 AM   #3
yah its totally missing all those wires, thought it was weird cuz I put this motor ina 94 HB and it had all tose wires but noo vtec wires. noticed today when I looked at a civic with a sohc vtec.
its a base model sedan..........only option it has is tilt sterring wheel and power steering.
Old 07-16-2004, 03:26 AM   #4
no I can send u a pic if you want, the top of that plug from the body harness has no wires coming out, it has the vtec wires now , but not those other 3.
Should it have those plugs to be running a 1.5 L. this is weird.
Old 07-16-2004, 03:36 AM   #5
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Yes, it should have the MAP sensor wires.
95 CX|B16A2
Old 07-17-2004, 10:47 PM   #6
did any 5th generation sedan civics come with sohc vtec engine from factory because I'm guess ing the didn't because of the missing wires
Old 07-17-2004, 10:56 PM   #7
Rep Power: 14 crxsoldado is off the scale
Send a message via AIM to crxsoldado
del sols si93-95,civic si hatch 92-95 and civic ex 92-95 all came with the sohc vtec(d16z6)
crxsoldado is offline   Reply With Quote
Old 07-18-2004, 01:03 AM   #8
so no sedan came with v tec engines.
So is a non vtec civic sedans wireing harness different then a vtec civics harness.
Old 07-18-2004, 01:10 AM   #9
2265787829
2000Si's Avatar
Ride:  Refer to my name, dumbass.
Rep Power: 285 2000Si has a reputation beyond repute2000Si has a reputation beyond repute
2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute
sohc vtec d16y8s came in civic EXs, which had a 4 door and 2 door platform.
XBL: jams 8201 (14,580G)
Lego Sears Tower: 82 stories/75.9% complete
CL2, CL3, CL4, CL5, CL6, Car, Mortgage
Originally Posted by eg6sir View Post
yea.. but aren't you spaghetti noodles covered in skin?
2000Si is offline   Reply With Quote
