JDM B16 in eg: vtec problem
Old 08-02-2006, 07:28 PM   #1
Rep Power: 0 RaYnE is on a distinguished road
Default JDM B16 in eg: vtec problem
Car: 95 cx hatch
Motor: JDM B16a SIR II (stock I/H/E)
ECU: chipped p28So I got the motor in this weekend, didnt hook up vtec, threw 4 codes.
20 - electrical load
21 - vtec solenoid
22 - vtec pressure
36 - traction control
I hooked it up last night, only got code 20, went for a test drive and I didnt feel it kick in.
I pulled over and checked the cells, got codes 20, 22, 36.
Today, i took out the vtec pressure pin, put it back in and again, only code 20.
I went for a test and didnt feel it once again, checked the cells and this time, codes 20, 21, 36.
Grounds have been checked, my oil level, both look good.
(Ive read that vtec wont engage if there are other codes. Is this true??)
i think if code 20 is eliminated, it will work.
Im kinda out of ideas though now. Can someone steer me in the right direction??
RaYnE is offline   Reply With Quote
Old 08-02-2006, 08:20 PM   #2
Führer Mod
eg6sir's Avatar
Ride:  Le Car
Rep Power: 382 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace  FaceBook
wow.. all those different codes.. something seems wrong.. did you wire the knock sensor or ground it at least.. i know vtec wont work unless you you've done that
DO NOT PM ME WITH TECH QUESTIONS!
XGT: cEElint
Originally Posted by 93civicracer View Post
my dad owned a Chevelle with a hemi that he claimed made 600hp.
eg6sir is offline   Reply With Quote
Old 08-02-2006, 08:25 PM   #3
its a chipped p28, theres no knock sensor.
Old 08-02-2006, 08:46 PM   #4
Führer Mod
eg6sir's Avatar
Ride:  Le Car
i'd double check that you have the right plugs on the right sensors.. you may have mixed them up on accident or forgot one.. i know i have
XGT: cEElint
Weird VTEC problem... D See 2 General Tech and Maintenance 23 05-18-2006 12:14 AM
YAY....VSS fixed now problem with vtec...then im done -94-AccordH22 HYBRID -> BA-BB /CA-CD 5 05-15-2006 09:17 PM
vtec problem , did almost everything redcivic_eg6 General Tech and Maintenance 8 11-18-2005 09:44 PM
Turbo B16 Vtec ChaseRsX Engine Building 3 04-10-2003 05:08 AM
