jdm b16 in ek
Old 10-08-2003, 11:48 AM   #1
ek9r is off the scale
Send a message via AIM to ek9r
im asking about this for a friend of mine.
its a obd1 jdm b16, in a 97 civic hb hes running a p72
problem: car runs fine, has vtec, then one day on the parkway, it starts running like shit, shuts down, and the ecu blows out. he opens the hood, sees nothing wrong, gets towed home cause obviosly the car wont start from the ecu being fried. turns out one of his injectors cracked, allowing fuel to enter the area on the injector where it plugs to the harness, in turn causing a short.
new injector, new p72: it happened AGAIN! WTF!
anyone have any ideas? no cel's
thanks
suck it sideways sister
ek9r is offline   Reply With Quote
Old 10-08-2003, 01:37 PM   #2
darwins_vtech is off the scale
Send a message via Yahoo to darwins_vtech
how long did it run right? are you absolutly sure all the wires are connected right- the difference between OBD1 and OBD2. Is there a fuse for the ecu under the hood or did yuo make a jumper wire. check that. You should have blown that before it goes all the way to the ECU. what kind of injectors are you running?
DArin
darwins_vtech is offline   Reply With Quote
Old 10-08-2003, 01:57 PM   #3
using the jdm b16 injectors, car is running now after another injector was replaced, but ill look for that fuse
TONS of parts for sale B16, GSR, Type R Envy_Motorsports Parts: For Sale/Trade/Wanted 28 02-08-2010 09:43 AM
B16 into 90 Integ EFB18A1 HYBRID -> ED-EF / DA 10 02-19-2004 01:19 PM
building a b16 jinstuh Engine Building 2 02-03-2004 10:03 PM
Hybrid jdm b16 tranny crxfreak HYBRID -> ED-EF / DA 2 06-30-2003 08:55 PM
B16 Block Ls Head, What Should I Exect? kanscrx Engine Building 9 01-18-2003 03:39 AM
