| | LinkBack | Thread Tools |
| | #1 |
| Junior Member | I'm almost ready to begin the swap. The engine is on order and should be here in a week. I've read up on the v-tech wiring. The po8 ecu will be here w/ the engine. Is it easier to do the swap without removing the transmission, or do i have to pull the whole thing, swap the trans out of the car and reinstall w/ the new engine? |
| | #3 |
| Senior Member Join Date: Feb 2008 Location: woodstock Age: 25
iTrader: 0 / 0% Ride: 89 CRX SI (LS)
Rep Power: 6 | I agree it would be much easier to remove/replace tranny while it is out, much easier. Probably easier to remove/replace motor and tranny as a whole anyways. |
| | #4 |
| Junior Member | ok, time for an update and a few questions. First, the engine is in and mounted. the wiring is plugged in except for a few things. Regarding the sensor found on the back of the intake of the old d15b7 that has a vacuum tube running from the intake manifold and another from the top of the canister. It has a 2wire plug w/ a red wire and a yellow w/ black wire. What is it? What do i do w/ the old vac line? Do i need it w/ the po8 ecu? |
| | #5 |
| Junior Member | ok, I think i've figured out what it is. The pcv system purge valve. It uses intake vacuum pressure to open the pcv valve. The new question is, what does the sensor do? Will the p08 ecu monitor this? Can I use a "T" fitting on one of the other intake vac lines to hold it open? If I do, am I gonna have issues w/ the other items controlled by that line? |
| D15b7 to JDM D15b | Elnyne | HYBRID -> EG-EK / DC | 0 | 10-12-2008 10:43 PM |
| D15B7 - D15B Swap Questions | SLAM1024 | HYBRID -> EG-EK / DC | 3 | 09-02-2008 08:17 AM |
| WTB d15b7/d15b vtec swap | 93civicracer | Parts: For Sale/Trade/Wanted | 0 | 05-16-2007 05:07 PM |
| del sol swap: D15B7 to a JDM D15B | raelsmith21 | HYBRID -> EG-EK / DC | 5 | 02-20-2007 05:38 PM |
| Help on a 96-00 D15B swap in 93DelS D15B7 | godspell | Civic and del Sol - EG and EK | 4 | 08-22-2006 08:02 PM |
