My mechanic is putting in a 97 JDM ITR engine into my 95 GS-R.
The swap comes complete with OBD2 and harness I would like to keep the GS-R ecu because it is easier to tune later on. Any suggestions as to what has to be done? thanks |
so you have a obd1 engine with a JDM obd2 type R harness and a obd1 gsr ecu?
unless your car is right hand drive i dont think a jdm harness fits your car. and if you wanna use the gsr stuff i say switch to a gsr harness. __________________
my <a href=\'http://www.hondaswap.com/gallery/browse.php?album_id=668\' target=\'_blank\'>civic</a> can burn stationwagons.....when they're parked |
#3 | |
Member of the 20 nut club
distributor
fuel injectors alternator those will be your only issues either swap the parts for your OBD-1 peices, or swap the plugs from the JDM harness __________________
МОΛΏΝ ΛΑΒΈ |
Use the GSR's engine harness, the GSR's distributor, and the GSR ECU and you're good to go.
What happened with your GSR engine? Did it blow to pieces or something? __________________
T3T67 ![]() <a href=\"http://www.hondaswap.com/forums/index.php?showtopic=69573\" target=\"_blank\">Buy my MSD 6AL, Carsound Cat, VTEC Distributor!</a> <a href=\"http://ipods.freepay.com/?r=11169222\" target=\"_blank\">Sign up for a Free Ipod!</a> |
#5 |
![]() use the gsr dizzy, gsr alternator, injectors. I would also run an ITR base map on either a p28 or your p72 ecu __________________
| 99-00 civic Si cluster swap into EF How To (pics0) | B18C5James | HYBRID -> ED-EF / DA | 30 | 07-11-2007 06:25 PM |
| Free set of VX wheels wiring my swap. GSR into VX | dwnthehatch | HYBRID -> EG-EK / DC | 3 | 08-24-2003 05:15 PM |
| Swap B16a Into Crx, Need Wiring. | joeblack | HYBRID -> EG-EK / DC | 2 | 04-16-2003 12:32 PM |
| H22 Wiring Harness For 92 Civic Swap | 300hph22civic | Engine Building | 2 | 02-09-2003 04:55 PM |
| H22a Wiring Harness For My Swap | 300hph22civic | Engine Building | 4 | 02-09-2003 04:13 PM |
