This is a discussion on JDM question... in the HYBRID -> EG-EK / DC forum
Ok, I heard a couple of things and want to put this to rest.
If I were to purchase a jdm engine, would I be able to use the engine wire harness it comes with?
I heard some crap that you can't because it is ...
| | #1 |
| Ok, I heard a couple of things and want to put this to rest. If I were to purchase a jdm engine, would I be able to use the engine wire harness it comes with? I heard some crap that you can't because it is setup for RHD. Is this true? Also, jdm engines often have a higher compression ratio then usdm, and I heard they require a higher octane of gas then usdm. So does a STOCK JDM b16/b18 require the higher octane? Thanks |
| | #2 |
| as far as the octane goes in japan they run on higher octane, not exactly sure what octane it is but i know its higher. as far as the harness goes you can still use the harness that comes with the motor but it would be a lot easier to use the harness thats already in your car. At most all you half to run is the 2 vtec wires to your ecu ground one pin the knock sensor to your ecu and if your getting a b18c then you gotta wire the secondary intake. not 100% sure tho so if im wrong someone correct me
__________________ 94 cx hatchback mods exterior- si wheels rapped in falken azenis, carbon fiber hood, carbon fiber wing, projector head lights, si paint job and m3 mirrors under the hood - b16 sir2 swap, clucth masters stage 3 clutch,act lightend flywheel, eagle rods, arias pistons, darton sleeves, rc 370cc injectors, msd plug wires,jackson racing fuel pump, apexi avcr and vafc, thrermal 3 inch turbo exhaust, 3 inch down pipe, auto tecknic fuel rail, b and m fuel pressure regulator,aem cam gears, turbonetics t3/t4e turbo, spearco fron mount intercooler, greedy type s b.o.v, future mods- crane 2 step rev limiter igniton system, pnp head, crower valve train, and a apexi power fc. |
| | #3 | |
| Quote:
Please correct me if i'm wrong, for I'm still learning. What I want to know is, if I got a sir2 or b18b/c...would the jdm harness that comes with the engine, plug into the harness on my chassis. (excluding wiring vtec and assuming obd is the same) Also, would I be able to use regular 87 octane or do jdm engines require a higher octane? Thanks | |
| | #4 |
| The ECU in a JDM is on the otherside of the car, so all the connections are on the other side of the car, which means if you try to use the JDM harness, you have to extend the canon plugs to the otherside of the car. It can be done, I know somene that did it, and felt stupid for wasting all the time and not just using his own harness. You can use you CX harness (as long as it is the same OBD as the motor), and you will need to extend a couple wires on the tranny side because the DOHC is a bigger motor and they don't reach, but it plugs right in. Also you will have to run extra wires depending on the additional systems your motor has ie: vtec, IAB's (on a GSR), knock sensor (unless you run a chipped ECU), etc... As far as the octane, 10.4:1 isn't that high, but I would still use the best I could afford to be safe, but you should be fine on nasty ass 87.
__________________ 86 CRX Si | 89 CRX ZC | 90 CRX ZC | B16A2 swapped 92 VX and 95 CX | 99 Civic EX ...swapped? boosted? blown? ...stock XBL/PSN | binary xj0hnx | Battlefield 3 360 www.svc.com www.ronlund.com So if someone throws a rock and knocks you off your donkey, are you stoned off your ass? Donate bitcoins here for hookers and blow -> 171TVTig4yXrGX2K17FFmTfHnTctc6YxzQ |
Similar Threads | ||||
| 90' HB DX w/d15, auto \ going to d16 ECU QUESTION | lcompeau | ECU's, Electronics, and Tuning | 2 | 05-28-2004 09:25 AM |
| 93 HB CX B18a1 swap question (OBD1) | dwn2low | HYBRID -> EG-EK / DC | 7 | 03-07-2004 12:05 PM |
| A question to everybody... | TWAN | Members' Lounge | 33 | 02-12-2004 07:31 PM |
| QUestion on LS swap | Hatchback 95 hybrid | HYBRID -> EG-EK / DC | 3 | 08-23-2003 02:24 AM |
| Basic turbo question | zueke | Forced Induction | 6 | 10-28-2002 06:04 AM |
