HI. I have a 99 JDM B16 SIR II into a 1993 Civic EX. I need a passenger side axel though. Now do I have to use a 1999 Civic SI or which type? Then to wire up the knock sensor so I don't have a check engine light, which spot on ecu does it plug into? This site says D3, but I have a wire that is already connected into D3? What do I have to do with that? All help is appreciated!
Darin |
B happy
Ride: dohc 95 egg
You can use any 94+ B series passenger axle. On the knock, yes there is a wire at that spot in the harness, but on the P28 it doesn't do anything, when you plug in your P30, you should just be able to tap the wire that is there. What ECU are you using anyway?
First the axel, I got a 99' SI now, so that should work. then the wire. I want to use the P30 because that is the right one for the swap, but if it makes a check engine light go on, then I just want to use the EX ECU and have it chipped.thanks. let me know what you think is better.
Darin |
#5 | |
B happy
Ride: dohc 95 egg
