I recently swapped an obd1 gsr engine (b18c1) into my 94 dx. I wired up the knock sensor but my p72 is throwing the cel code 23. Since I am 100% sure it is wired up correctly my only guess is that my knock sensor is no longer working. I searched and people said that everytime the knock sensor detects knock it pulls 3 degrees of timing and adds fuel until it no longer knocks. The question is how much timing does it pull if it is not working correctly. Does it just pull the initial 3 degrees? Also I went and checked on a price for a new knock sensor from Acura and it's like $140 so I was wondering if there is another knock sensor that will work. Many mr2 guys will just buy a GM 1 wire knock sensor and get a convertor that will convert it to the correct threads and pitch, suprisingly it will not trip out their computer. Has anyone tried anything like this?
Also throwing in a chipped p28 is not an option because I need to get it B.A.R. certified. |
i get knock sensors from the shop that works on my car for $20-40. hit up a honda-acura shop they will have better prices as long as you dont mind a used
93 Si HB, B16A swap OBD1, GSR hydro tranny, 6 puck clutch,`1 Nitrous Express NXL 60shot ,Front and Back Strut bars, 99 Si rims, 2.25 Exh w/ flowmaster axle back, Ebay Short Shifter, Ebay intake, Megan Type R replica 4-1 headers dynoed on old tranny and stock clutch was 137 WHP and 177 w/ nitrous Our rides are dubbed rice burners because we aren’t housing some outdated, pushrod,gas guzzling, carbureted, iron-block V-8 engine under our hoods. What out industry has takes a lot more technique. Forcing 250 HP out of a tiny 1.6L engine.... Now look where the so-called rice burners are. Four-bangers are spinning more then 1,000 hp on the dyno and knocking down Pro stock-like times down the quarter-mile. |
