Discuss Swap information, turbo installation, general Honda tech, ecu chipping, and tuning at HondaSwap.com
Members have access to more features and see fewer ads! It's free, what are you waiting for?
92-95 EG & Del Sol with a 94-2000 Integra LS B18B Engine.
Transmission: These Engines come with Hydraulic clutch transmissions including Japanese or American market Y21, Y80, S80, AND S4C. Japanese or American market S1, J1, A1, Y1 or YS1 cable clutch transmission with Hasport cable conversion kit part # M92-CC can be used. Mounts: A combination of stock and integra mounts can be used if a hydraulic B- series tranny is used. on some 96 and up engines you may need to change the bracket under the timing belt and on the rear of the engine for ones of the appropriate year. ECU: p75 from a 94-95 Integra Electrical Differences: CX and VX need to convert to 4 wire o2 sensor. All models modify stock harness to fit. Axles: 90-93 integra axles, 94-up integra axles, 94-97 Del Sol Vtec axles, or 99-00 Civic Si Axles. Note the intermediate shaft seal in the left side of transmission is different for 90-93 Integra Axles. Depending on Axle transmission Combo, It may have to be changed. Hasport Part#: EGBAXCMP Shift Linkage: 94-up Integra linkage for Civics. 94-97 Del Sol Vtec linkage for Del Sol Upper Radiator Hose: 94-Up Integra LS Lower Radiator Hose: 94 Del Sol Vtec Throttle Cable: 94 Integra LS Clutch Hydraulics: Stock Air Conditioning: 94-95 Del Sol Vtec A/C bracket Special instructions: Using OBD II Ecu requires involved wiring modifications. Generally if the ECU you choose does not use the same plugs as the stock ECU, an Adapter harness will cut down on alot of potential problems |
#6 |
Crusher of Noob Ambitions
Ride: 97 Integra LS Coupe
If the motor comes from a 92 or 93 Integra, then the swap will be exactly the same as the one outlined above. If it comes from a 90 or 91 Integra, then an OBD conversion will need to take place...
If you find anything I say helpful, please leave me some rep... 97 Integra LS Coupe: *AEM Intake/Megan Header/Magnaflow Exhaust *Tokico Shocks & Springs *Megan Strut Braces & H-Brace *98-01 Conversion (Front/Rear Bumpers & "Mesh" Alloys) Please DO NOT PM me with tech questions! Ask your questions on the forum so we can all benefit from the answers... |
#8 |
Start your own thread dude...
#10 |
90-93 Integras use a cable setup. A GS-R or B16 transmission will bolt right up and help with acceleration but you might also see a slight decrease in gas mileage...
#12 | ||
Honda Enthusiast
Ride: '94 EG sedan w /Z6, '97 EK hatch
Yes, that is correct.
Max? There is no max. Max just means you gave up. This is my thread: http://hondaswap.com/engine-building...g-wind-110848/ My for sale/trade thread http://hondaswap.com/parts-sale-trad...1/#post1048406 Quote:
#13 |
another thing. the b16a pistons will work in this motor right? and which are ones are compatable. the ones from the ek si motor, or from the jdm sir b16a? sorry for all the ?'s i would search but for some reason it never works properly.
#14 |
You want the JDM pistons, and I didn't mean to sound like a dick with the comment about the mileage, I was just letting you know. If you're fine with it then yeah, go for it...
#16 |
I'd probably take it somewhere and get a tune if you're going to be swapping out the pistons and messing with the cam timing...
#18 |
Deff go with the b16 trans. I had an LS in my 4 door civic with a y21 trans I had a blast with it driving around town. Gas mileage wasnt bad either i was still getting 300+ in a tank. As for tuning you should look up phearable.net you can buy an already chipped ecu from them with a basemap and then just go from there
#20 |
sounds like a decent plan , sorry to be short the other day with the long swap post , but an ls swap is one of the easiest swaps . are you changing cams or just pistons and valve train ?
some after market valve train parts are great with a cam swap , but on stock cams it can be a waste of money . remember you can't rev the shit outa an Ls or an Lsvtec , any way good luck with the swap , just keep your expectaions real and in your budget |
#21 | |
As for the tuning, you can get your ECU chipped and look for a map that roughly matches your engine build, but ideally you want to tune it on a dyno, so you'd probably need to take it somewhere. I suppose if you're going to use a piggyback like the V-AFC you could research it and perhaps do some tuning yourself. Still though, I'd say it's probably better to have it tuned on a dyno...
#23 | |
