| | LinkBack | Thread Tools |
| | #26 |
| Senior Member Join Date: Oct 2006 Location: harford co MD Age: 23
iTrader: 0 / 0% Ride: 06 gmc 2500 Turbo Ls Civic
Rep Power: 31 | what you said is a good idea. b18b with pistons and rods, sleves couldnt hurt. and bild a turbo kit. you would be in the 12,s in the 1/4 and would put 300+ hp to the ground. on 15psi read up on what you want. do you want to be fast in the 1/4, do you want to be able to spin in all gears and never have traction, do you want a dyno queen. all depends from the sound of it you want a car that is fast at aceleration, so id stick with the b18b and turbo
__________________ Boost Big or Boost Small. Just make sure you remember the Boost. |
| | #28 |
| Junior Member Join Date: Sep 2006 Location: charlotte nc Age: 22
iTrader: 0 / 0% Ride: hondas
Rep Power: 8 | im running an ls setup thats making 200 whp at 5 psi,stockk motor 550 rc injectors and a t3 turbo with 3 inch downpipe and straight pipe.. i run 10 psi and my car is just fine had it boosted since the begining of summer good tune = reliability ls stock on good tune run 10 psi all day ull be good i know pple that run 5 psi untuned on an ls...and there motor still running strongggg... dont change anything on the ls unless u waNNA go over 300whp or 13- 14 psi and up |
| | #30 |
| Byaaah! Join Date: Nov 2006 Location: Frederick,MD Age: 22
iTrader: 0 / 0% Ride: 91 Civic hatch
Rep Power: 8 | this is my setup on my 91 hatch. t3/t4 10psi dsm 450's+vtak got me around 230whp. only cost about a total of 12-1300. just a thought.including dp,fmic,injector resistor box. o yeah i threw all the rods at 13psi so be careful however much u boost |
| | #32 |
| Senior Member | Okay this is what I heard from other forums. B18b OBD-1 is a little faster and easier to work on. B18b OBD-2 is a little slower and harder to work on. Does anyone think this is true????? |
| | #33 |
Rep Power: 31 | obd1 is best in my opinion. you cant chip obd2 so.... you can convert to obd0 but there are more options for obd1. and ls block is a beast. obd1 and obd2 engien are basically the same thing not any real power dif. you cant chip obd2 and thus you cant tune it reliably. would have to use a fmu or a hack wich are both shit imo. |
| Centrifugical Supercharger Vs Turbo | JDMSpecAccordSir-T | Forced Induction | 49 | 05-24-2007 12:44 PM |
| Boost & HP Level | Turbo&Auto | Forced Induction | 56 | 09-13-2006 12:18 AM |
| SOHC TURBO BUILD-UP QUESTIONS | whos_the_master | Engine Building | 17 | 10-10-2004 05:49 PM |
| D16 turbo questions | SolLess16 | Forced Induction | 12 | 08-20-2003 05:50 PM |
| difference between turbo sizes | SnailOnARampage | Forced Induction | 4 | 11-12-2002 03:53 PM |
