ls vtec issues please help
Old 11-01-2009, 11:38 PM   #1
Rep Power: 1 Rjs4490 is on a distinguished road
Default ls vtec issues please help
1st problem : At sometimes my car has no throttle response..TPS sensor??what should i do?
2nd problem : Car does not always have v-tec...Pressure Switch??what should i do?
The car throws 3 codes..1, 7, ans 22
1 = o2 sen
7 = TPS sen
22 = V-tec Pressure sen
I just need some advice on this rather than go out buyin a tps sensor, pressure switch ect..
Description of my car:
93 honda civic vx hatch
built lsvtec
95 b18b1 block
oem honda pr3 b16 pistons 11:5.1 comp.
oem honda piston rings
arp rod bolts
oem honda crank and rod bearings
type r oil pump
gsr water pump
gsr timing belt
oem honda headgasket.
hondata intake mani gasket
p30 b16 intake manifold
dc sports race header with 2.5 inch collector
2.5 inch exhaust with 2.5" vibrant muffler
golden eagle lsvtec kit
99 b16 head
supertech valve springs and retainers
gsr cams
gsr trans with act clutch
chipped p28 ecu
Rjs4490 is offline   Reply With Quote
Old 11-03-2009, 07:30 PM   #2
Rep Power: 0 intenseneal can only hope to improve
You need to trouble shoot the codes to eliminate and find what is causing th codes. A Honda/Acura service manual will have all the steps to do the trouble shooting.
intenseneal is offline   Reply With Quote
Old 11-06-2009, 11:36 PM   #3
F.I. Junkie
Ride:  1996 Civic, 1992 Accord
Rep Power: 101 Matts96HB has a reputation beyond repute
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
Send a message via MSN to Matts96HB
You said VTEC does not always work, so when does it?
As for the o2 sensor, is it an OEM sensor?
The TPS has got to be some sort of a wiring mixup because you are running an OBD2 head with an OBD1 ECU, I'll do some research and see what I can find.
XBOX LIVE GT: teb00stcat (00's are zeroes)
-320 WHP EJ6-
Matts96HB is offline   Reply With Quote
Old 11-07-2009, 04:34 AM   #4
Dark93DX's Avatar
Rep Power: 10 Dark93DX is on a distinguished road
every sensor has a test procedure, you say you have have a chipped P28, have you thought about getting it tuned properly?
K20Z3 EG - Installed, waiting for Kpro
LSD w/ 4.764 FD
B18A CRX
Dark93DX is offline   Reply With Quote
Non Vtec Auto to Vtec Manual swap issues! thekingofvtec Accord 0 09-08-2009 08:20 PM
1.9L ls/vtec blow by issues? Somalia757 Engine Building 5 07-09-2008 08:46 AM
vtec issues haao13 Civic and del Sol - EG and EK 9 08-29-2007 04:13 AM
LS/Vtec Issues!!!!! k24hatchback HYBRID -> EG-EK / DC 2 10-14-2006 03:57 PM
vtec issues hb90racer ECU's, Electronics, and Tuning 4 07-02-2005 06:52 AM
