MY FRIEND HAS A LS MOTOR HE WANTS TO SELL AND I WAS THINKING ABOUT BUYING IT. I WANT TO KNOW HOW RELIABLE IT IS. BLOCK HAS GSR CRANK AND GSR RODS AND STANDARD JDM ITR PISTONS. THATS ALL THAT IS NONE TO THE BLOCK. B16 HEAD WITH GSR INTERNALS. OIL LINE IS HOOK UP TOO. HOW RELIABLE IS THE BLOCK?? CAN I GET oil squirters and crank girdle INTO THE BLOCK EASY??? WILL I NEED IT? IS IT WORTH IT TO TRY AND DO THIS??? WANT MOTOR TO LAST AND NOT BLOW UP. ANY IDEAS, LET ME KNOW WHATS UP. THANKS PEOPLE
first off 86 the caps lock, and yes if done right it will work just like any other B series, done right means getting the right headgaskets, sealing the oil passage, getting a lsvtec oil kit which costs almost nothing, honing the sleeves for new pistons, new rings, bearings, seals, gaskets and will work find. Z10 crank girdle is recommended for high rpms with that block.
good luck. __________________
#5 |
my mistake, it has ls rods and crank. will the block be able to rev to 9000 with no problem?? i really dont want to spend much to make is new, so what can i do. i have let 300 bucks left after i buy the motor. what should i get?? i want to use the same piston. how can i make the block more safe with much money?? any suggestion on what i can do???? i am hopein that one of my friend can build it for me so no machine work. or should i just buy motor and save up.
#8 |
88 C1V1C 53D4N DR1V3R
Ride: 2006 Suzuki Aerio
if it is just a stock b18b motor, you should be able to get a complete swap for around $900, not just the motor.
if its a ls/vtec, and you already have all the extra b-series stuff you need (i.e. tranny, ecu, mounts, linkage, etc.), and you trust your friends building skill, then i say pick it up if its in good condition. |
| fuel pressure for lsvtec | m2slsvtec671 | Engine Building | 1 | 03-09-2004 06:14 AM |
| Lsvtec Or Crvtec Project | rsaeini | Engine Building | 12 | 06-05-2003 02:52 PM |
| How to make an LSVTEC pass smog. | 99lsvteccivic | General Tech and Maintenance | 1 | 03-06-2003 11:31 PM |
| lsvtec pistons | khan | Engine Building | 21 | 10-12-2002 04:54 AM |
