Map sensor problem with h22 swap
Old 07-07-2009, 03:44 PM   #1
senior member
97h22dxcoupe's Avatar
Ride:  97 h22 civic dx
Rep Power: 5 97h22dxcoupe will become famous soon enough
Send a message via MSN to 97h22dxcoupe myspace  FaceBook
Exclamation Map sensor problem with h22 swap
does any one know if i can use the map sensor vacuum box (which is located underneath the injection mani)so can i just plug in my map plug from harness instead of the fire wall??
97h22dxcoupe is offline   Reply With Quote
Old 07-07-2009, 03:50 PM   #2
yep....mmhhm.......yep...
DESPAIN's Avatar
Ride:  92 PRELUDE SI
Rep Power: 83 DESPAIN has a reputation beyond repute
DESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond repute
Send a message via Yahoo to DESPAIN myspace
You use the same plug. Just that one map is on the firewall instead of on the throttle body. If you have one on the throttle body and on the fire wall......like mine does. You can use either one. But you must use one of them. If this helps rep me. If not than dont......well? To rep or not to rep is the question....lmao. Iam so bored today!!!! Going to send that bracket and injectors today i hope. If not in the morning. Unless you want me to send the injectors then send the bracket later? Let me know
Hugh.......I like money.......
"idiocracey"
Originally Posted by DarkHand View Post
Strippers eh? That'll get you a good view of the elusive pink snapper, but don't try to catch the ones around there, they usually have parasites.
Originally Posted by phyregod View Post
Probably waiting on an equipment upgrade.
"This tower runs hondaswap, Those 14 racks over there run the GF pic threads"
DESPAIN is offline   Reply With Quote
Old 07-07-2009, 04:01 PM   #3
DESPAIN's Avatar
Ride:  92 PRELUDE SI
Yes either map will work. Either the one on the throttle body or the one on the fire wall. Will post pix in one sec.
"idiocracey"
Old 07-07-2009, 04:05 PM   #4
DESPAIN's Avatar
Ride:  92 PRELUDE SI
And fyi. Mine is hooked up to the one on the fire wall. And the two vac lines dont go to anything they are plugged in to a vac tree thing and then they dont hook up to anything. So i guess they dont have to be hooked up
"idiocracey"
Old 07-08-2009, 11:12 PM   #5
senior member
thx man appreciate the info...
o2 Sensor Problem?? 1sikef Civic and CRX - EF 3 08-13-2008 11:05 PM
Map sensor problem with B16 J240sx ECU's, Electronics, and Tuning 0 01-07-2008 09:57 PM
02 sensor problem 92d15b ECU's, Electronics, and Tuning 1 05-18-2005 04:13 PM
o2 sensor problem jdmhybridcivic HYBRID -> ED-EF / DA 4 07-20-2003 07:47 AM
O2 Sensor Problem Please Help ? rexheadb16a ECU's, Electronics, and Tuning 0 06-02-2003 06:18 PM
