| | #2 |
| RETIRED | i bought one with 80. if you ar erebuilding it, i wouldn't aorry too too much about it, as long as its mecahnically sound. what wears down are the rings... and since you are replacing the pistons, new rings will be going on anyway. its the rings that cause lower compression (not overall.. but cly compression test thing). |
| | #3 |
| GNU/Linux Evangelist Join Date: Sep 2002 Location: Greater Portland, OR
iTrader: 0 / 0% Ride: The Cheapest Road Bicycle I could get
Rep Power: 70 ![]() | The rings are not the only things that wears, they wear the fastest. If you are replacing the rings in your motor you should replace the timing belt/water pump unless you know that it has been done recently. The oil pump would be good. Get an ITR oil pump, you don't need it, but extra oil flow is good. Check your main/rod bearings for wear and replace them if nessecary. Replace your thrust washers. Replace all the seals. While you have the bottom end apart why not replace the clutch anf flywheel as well. |
Similar Threads | ||||
| Compression VS. Gas mileage | phyregod | General Tech and Maintenance | 18 | 09-08-2005 01:06 AM |
| 97 civic shell (perfect swap) | b18c1civic97 | Vehicles: For Sale/Trade/Wanted | 36 | 04-25-2004 05:42 PM |
| The latest GS-R find | UDT | General Tech and Maintenance | 24 | 04-01-2004 12:20 AM |
| What's Your Gas Mileage? | Wytt | HYBRID -> EG-EK / DC | 7 | 03-23-2003 01:33 PM |
