Mini Me Vtec
Old 06-14-2004, 02:21 AM   #1
Rep Power: 12 MugenPower86 is off the scale
Ive got a civic cx, and i have all of the parts necesary for a mini me vtec swap, i was wondering if i could use the same fuel system thats on my cx for the mini me
Also if anyone knows any sites with mini me vtec swap info, please post I want to get this done right
MugenPower86 is offline   Reply With Quote
Old 06-14-2004, 01:22 PM   #2
Rep Power: 12 Unit02VXHatch is off the scale
Send a message via MSN to Unit02VXHatch
I am also looking for some sort of online guide to swap a mini-me into my VX hatch. So any Info would be appreciated.
Unit02VXHatch is offline   Reply With Quote
Old 06-14-2004, 01:24 PM   #3
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Yes, you can use your stock fuel system. It's perfectly fine for a mini-me setup.
If you're looking for info, use the search feature on the site. There's plenty of good information here on HondaSwap, and even more outside.
Old 06-14-2004, 03:53 PM   #4
Rep Power: 12 b20z2 is off the scale
fyi
if it's a D15 mini-me you will need a cam gear to correct the timing and you will also need to remove the oil control jet from the block.
i have a mini-me set-up in my 92 civic 4dr. It's a d16y7 with a d16y8 head that set-up did not require a cam gear and there is no oil control jet to remove.
D15 block with a d16z6 or d16y8 head will require a cam gear.
Make sure you use a p28 ecu. I converted my p06 to p28.
With i/h/e and act clutch my best time was 15.9. can't remember the speed.
hope that helped some.
good luck.
95hb, b20z2, 91teg s1 tranny, act clutch, auto-to-manual conversion. cable all the way.
b20z2 is offline   Reply With Quote
Old 06-14-2004, 06:18 PM   #5
Kung Foolin'
Ride:  1990 Integra GS
Rep Power: 39 StealthMode has a spectacular aura aboutStealthMode has a spectacular aura aboutStealthMode has a spectacular aura about
Send a message via AIM to StealthMode
yes you can use your fuel system. i did the same swap (if it's a d16z6 head swap) on the same car and it works great. i'm not sure about REMOVING the oil control jet altogether, but i replaced mine with the jet from the EX it was like 2 or 3 dollars straight from Honda. probably works either way. i did a skunk 2 cam gear too. jdm intake manifold after my IAC valve went bananas. looking for the Si tranny
On a quiet night, you can hear a d-series ninja being born. . .
StealthMode is offline   Reply With Quote
