motor mount install sequence HELP!!
Old 05-26-2007, 08:15 PM   #1
learning in progress
formby's Avatar
formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
Default motor mount install sequence HELP!!
i dont know if i have the mounting sequence right..
99 ek with b series engine and cable tranny w/conversion mounts
is it like this?
bolt T bracket to the back of tranny and block.
position engine over bay.
lower engine with the hoist.
bolt T bracket to chassis.
bolt on Timing belt mount.
then bolt on tranny mount.
the problem i have now is that i put it in this way:
T bracket on the chassis
now the T bracket is too forward and i cant bolt it on...
HELP
http://pandora.com/
Old 05-27-2007, 09:06 AM   #2
formby's Avatar
up
Old 05-27-2007, 08:25 PM   #3
vtecsir1 will become famous soon enough
formby you put the t bracket on after you connect the driverside and tranny mount. i didnt even bolt it on until those 2 mount points were on.
you just need someone to torque the motor some from the valve cover too fit it in. you have the si bracket right?
vtecsir1 is offline   Reply With Quote
Old 05-27-2007, 08:38 PM   #4
formby's Avatar
yeah .. si bracket
he got it on
now it wont start
no fuel..
Old 05-27-2007, 09:26 PM   #5
whats the cel?
Old 05-28-2007, 11:34 AM   #6
onesikdb8's Avatar
Ride:  A Car....A Honda
onesikdb8 is off the scale
Did you take the engine harness out when you removed the old motor? If you did, make sure you hook up the green connector by the ECU, that has the fuel pump control wire in it.
onesikdb8 is offline   Reply With Quote
Old 05-28-2007, 05:46 PM   #7
formby's Avatar
ok
the engine is tilted forward, because i was sold the wrong T bracket... i thought that the teg bracket and the civic bracket were the same as long as the car had a hydro tranny and b series engine.
because i have a 90-93 teg bracket it it no workie.
the engine is on but i have some codes
6, then i cant figure out the other ones.
so anthony is ordering a 99-00 SI rear T bracket to see if it works. then the ac wont fit because the t bracket is wrong. but its stamped p30 so it has to be the one
http://pandora.com/
Old 05-28-2007, 05:54 PM   #8
onesikdb8's Avatar
Originally Posted by formby View Post
ok
The 99-00 Si Rear Engine Bracket will work with this swap. You need a P54 A/C bracket to bolt up the A/C compressor.
Code 6 is for the ECT, Engine Coolant Temp Sensor. Make sure it is plugged in and make sure the wire isn't broken at plug.
Old 05-28-2007, 06:24 PM   #9
formby's Avatar
yeah the ect is jumped right now because i broke the sensor i an going to buy a deep 22 to get the other one off of the d16
the idle is uber fucked... when he gets off of work he will come over and try to fix....
i thought the t bracket i got was from a b16... ill have to check my posts so i can find the thread... and make sure i was sold the right part. but it doesnt look that way
at least the wife is off tomorrow so i can take the montero to work
http://pandora.com/
Old 05-28-2007, 09:18 PM   #10
killercannible will become famous soon enough
You have to use the rear t bracket from an ek si, but there is another interesting option. The crv rear t bracket will also work because it is built on the same chassis as the ek civic.
killercannible is offline   Reply With Quote
Old 05-29-2007, 08:13 AM   #11
formby's Avatar
so, i was sold the teg bracket.... huh
ill buy the right one today
these things always happen to me.
with the rex it was the gd linkage
pics today
Old 05-29-2007, 10:01 AM   #12
formby's Avatar
pics of mount and t bracket
moure pics in here
formby/HIN - Photobucket - Video and Image Hosting
Old 05-29-2007, 07:39 PM   #13
yeah man it has to be the ek si bracket not a b16 bracket. 99-00 si civic only.
Old 05-29-2007, 07:57 PM   #14
formby's Avatar
thanks i got it today from the dealer $60
the front ac bracket....
do i need to remove the rubber and bolt? and reuse the stock civic peaces....
the bracket reads p30
Old 05-29-2007, 09:04 PM   #15
p30 is the one you need, although a 94-01 integra unit will also work for both front tourque mounts.
Old 05-30-2007, 12:13 PM   #16
formby's Avatar
look at this pice of shit
i guess anthony was right. i had the wrong bracket
Wtb Vtec Head ls ef Parts: For Sale/Trade/Wanted 6 11-09-2006 03:21 PM
Build a Reliable LS/VTEC hondacrxb16vtec General Tech Articles 0 10-06-2006 07:54 PM
auto to manual conversion d112crzy HYBRID -> BA-BB /CA-CD 0 09-13-2006 10:27 AM
How to build a "reliable" lsvtec/b20vtec bambam General Tech Articles 2 07-02-2006 04:48 AM
Drag kit install manual pissedoffsol Forced Induction 0 07-17-2004 11:37 PM
