Conan The Hondarian
Ride: 1993 Honda Civic Dx Coupe
I just want to be sure which mounts I need to get from an integra for my 93 civic dx. I am putting in a b16. I just need the bracket and rubber labeled 7 and 10 from this picture correct. The rest of the stock mounts will work?
Ride: 99 Civic EX
Im pretty sure you just need the T-bracket. Not the mount. I didnt use it in my 99.
"Dream as if you'll live forever. Live as if you'll die today." -James Dean 99 Civic EX AEM V2 intake Dynomax DNX Cat-back A'pexi VAFC2 AEBS intake manifold Pacesetter Header Tein S-Tech springs 16x7 ROTA GT3 rims on Falken Ziex tires Corbeau A4 fronts Si Rear seats ACU digi-camo armrest accents Black Si Grill Mugen 'style' Front Lip DIY Type-R headlights Integra Mesh Winter rims |
#5 |
HS Vendor
Location: 650n Barranca ave #a Covina, Ca 91723 (626) 261-4052
Ride: 00 Civic, 08 Fit, 98 EK
You can use your stock mounts with a 94-01 Integra Rear T Bracket. Aftermarket mounts on your swap are optional. What year is the B16A motor?
Innovative Mounts B-Series Motor Mount Kits __________________
http://www.SwapShopRacing.com Honda Performance (626) 261-4052 attn: Brian http://www.myspace.com/swapshopr http://www.facebook.com/swapshopracing http://www.twitter.com/swapshopracing |
#6 | |
Conan The Hondarian
I am not sure. It is a b16a (japanese model). Are you asking because of the mount that has two or three holes? And I just need the bracket not the insert correct?
XBL: Wikedeye Last edited by wikedeye; 10-15-2009 at 06:06 AM. |
#7 |
HS Vendor
If it is a 95-95 JDM B16A motor then you can use your stock mounts & the rear T bracket the motor came with. Otherwise you can use the rear T bracket from a 94-01 MT Integra.
Engine Swap Brackets for your B/D/H/K Series Engine Swap __________________
#8 |
Conan The Hondarian
Is there a way to identify the t-bracket. I have one that came off a 98 ex that I pulled my b16 from. Is there a number or something distinct that I can use to tell if it will work?
| B18 LS MOUNT 88 91 Civic CRX B16 Motor Mount Kit Engine | RSS-Bot | Auctions | 0 | 02-15-2009 09:17 PM |
| B18 LS MOUNT 88 91 Civic CRX B16 Motor Mount Kit Engine | RSS-Bot | Auctions | 0 | 02-01-2009 12:03 AM |
| This mount looks healthy, just replaced the motor mount on the Jeep. | 92civicb18b1 | Other Vehicle Discussions | 12 | 04-27-2008 06:56 PM |
| Integra post mount driver side motor mount B16 B18 B20 | RSS-Bot | Auctions | 0 | 04-14-2008 06:33 PM |
| Integra post mount driver side motor mount | RSS-Bot | Auctions | 0 | 03-28-2008 11:23 PM |
