My b18c swap is finished...two questions
Old 01-11-2004, 06:32 PM   #1
truoss is off the scale
car = 94 civic hatch cx
swap = b18c
I added these wires: VTEC solenoid, VTEC pressure switch, and IAB solenoid
Check engine light came on when I first stared engine. Code was 41. So, I connected the o2 sensor wire and now the check engine light is off. Engine is running great as far as I can tell. First question, is this all the wiring I need, or did I forget something?
I test drove the car for the first time today. Everything was great, but I noticed some clicking noises when I reached a certain RPM (don't know exactly, don't have a tachometer). Is this VTEC kicking in, or what? Is it normal? How can I find out if VTEC is really working?
Thanks a lot,
Tristan
truoss is offline   Reply With Quote
Old 01-11-2004, 08:21 PM   #2
Iquark is off the scale
Send a message via MSN to Iquark
You should know when the VTEC kicks in, you will difinitely know...
As for your question on the wires, What ECU are you useing?
The clicking is probably what caused me to adjust my valves five times, and really pissed me. Finally when I was changing my oil one day, I felt my O2 sensor was loose and tightned it. After that the noise went away forever.
Iquark is offline   Reply With Quote
Old 01-11-2004, 09:00 PM   #3
jdm p72
So, that clicking noise is not coming from VTEC kicking in?
Old 01-11-2004, 09:05 PM   #4
dohch22a4's Avatar
dohch22a4 is off the scale
Send a message via AIM to dohch22a4
There is a slightly audible "click" when VTEC engages, but it should be only one click and only at 4400 RPM. If it is a constant ticking, you probably need to adjust your valves. My B18C ticks at idle, but not any higher, I should probably get off my dead fat ass and adjust them, but whatever.
dohch22a4 is offline   Reply With Quote
Old 01-11-2004, 09:20 PM   #5
JDMilan is off the scale
No Cel's , which is good
It sounds like your running fine, not sure about the clicking though.
jdm Honda B18c GSR swap for sale racer98 Parts: For Sale/Trade/Wanted 3 01-01-2004 08:16 PM
b18c swap eclipsea4 HYBRID -> EG-EK / DC 4 08-06-2003 02:06 AM
b18c complete motor swap krossoverr33 HYBRID -> EG-EK / DC 3 07-21-2003 06:05 PM
Noob here, Question on b18c swap alllooksnnogo HYBRID -> EG-EK / DC 2 07-12-2003 12:31 PM
head swap questions toyzbus HYBRID -> EG-EK / DC 7 10-09-2002 11:17 PM
