Ride: '92 Hatch si w/B16 (wannabe EG6)
My '92 EG SI with a B16 (JDM). Great success!!! Just happy to finally get it in. It was definetly worth talking to people on this forum. It all went smoothly after I after i extended wires on the engine harness (D16Z6). I extended the O2, VTEC solenoid, and VTEC oil pressure. I also ran the knock sensor through the harness clips and to the ECU. And last was the MAP sensor needed to be mounted to the firewall and ran to the top of the throttle body. Thanks for all the help!!
Führer Mod
cool.. glad you got it finished.. nice rod in the back too
Gay username^
Ride: 97 Accord & 91 hf
cleeean. How long did it take you?__________________
97 f22 Accord exedy stage 2 clutch Full exhaust from header to muffler Cold air 17" Motegi Ro_Ja's Brembo rotors/pads ----------------------- 91 Crx Hf restoration: Motor: OBD-1 JDM B16a Trans: Hydro b16 for now Tokico Blues H&R Sport Springs Front Si Brakes Energy End Links/Bushings ....check out my build thread http://hondaswap.com/civic-crx-ef/ne...ration-281596/ Add me on Xbox Live!--- C Reese 517 cod4/waw/forza |
#5 |
I'm just EF'n..
Ride: 91' civic Dx
niice!
DONT FORGET TO REP A BROTHER. ![]() XBL Gamertag: SIROSKERCHIEFS (COD4,HALO 3,COD: WaW,soon to come COD4:MW2) 91 CIVIC HB DX:Stock B16a swap,lowered,sittin on slipstreams.
#6 |
It took me a good three days with:
Replace clutch/flywheel/timingbelt/waterpump/valvecover gasket I had to make a bracket to mount to the firewall for the MAP sensor (not attached to throttle body like USDM Hondas). Plus getting my knock sensor into the ECU plug was a time consuming experience. A little over 2 hours to take the LS swap out and 3.5 hours for the install of the B16. No Check Engine Light....just needed to advance the timing a little. Last edited by CAFROG; 06-09-2009 at 03:13 PM. |
#9 |
Here's the MAP sensor on the firewall. I just used the right side bolt of the fuel filter mount. I just took some semi thick sheet metal my dad had in the garage and marked the three holes for the map sensor (two for mounting and one big hole for the vacuum tube to attach to MAP sensor). Then I drilled another hole on the other side so I could run the Fuel filter bolt through it. Test fit it and bent it to my liking...then painted it and got a vacuum line that worked (about 8-10 inches long)
#10 |
The surge I feel is only when I give it more throttle then it wants (at the lower rpm) but I'm not sure if its from the motor sitting for so long or what. I put cheaper 10w-30 in it to flush it out and have synthetic that'll put in this weekend.
#12 |
I wanted a different set up (LS since '98) and I wanted a VTEC Head/Trans. I plan on either selling the LS swap or keeping the bottom end and building and LS/VTEC later on (maybe this fall).
#17 |
I have it but need the lines from the pump to my connectors...plus I need new rubber rings because I was told if the system is empty...the seals will go bad ( I haven't had A/C since '98). But I have the pump for it and will have it up and running before it gets too hot
#19 |
wow....that is a trip. not sure whats up with that....sounds like fuel or a solenoid/sensor on the intake/throttle body.
Check vacuum lines....sensors/solenoids for continuity. I advanced timing by jumping the service plug under my glove box and advanced timing by sound and figuring one millimeter was roughly one degree. counterclockwise rotation is advanced I put it on a gun and it looked like it was right on the money (16 degrees) I wonder if a mechanic retarded the timing in Japan so it could run lower octane gas?? My surge is coming from the lightened flywheel...i think. Someone told me about it and it makes sense because the hesitation is at low rpm and lightened flywheels can cause that |
#20 |
Here's a pic with the OEM air box and A/C hooked up
![]() __________________
"Meow, you know how fast your were going back there?" http://hondaswap.com/hybrid-eg-ek-dc...si-b16-286581/ |
#21 | |
!!YTINASNI
I haven't seen an oem airbox in a honda in years! lol
Nice job, very clean honda. Repped! __________________
#22 |
its so the fuzz will leave me alone!!! The air box keeps them out of my engine bay!
#23 |
Führer Mod
is your airbox insulated? i know my JDM one was..
oh and nicky, that sounds like a vacuum leak.. take some carb cleaner and spray it around the base of the intake manifold and whatever is attached to it.. if it starts to die out.. you found your leak |
#24 |
YES its insulated! You are the one that guided me to it at hmotorsonline.com!!
Well...the bottom of it is __________________
#25 |
Führer Mod
i know i told you where to get it.. just wasnt sure if all of them are insulated in the bottom.. when i got mine i bought it off H-T
| WTB: pre swap or post swap CIVIC hatch or coupe TEXAS? | tejaskid | Vehicles: For Sale/Trade/Wanted | 2 | 03-15-2008 05:02 PM |
| FS/Trade: Complete d16z6 swap and compete d16y7 swap | joshisakson_ | Parts: For Sale/Trade/Wanted | 6 | 03-20-2007 12:06 PM |
| b18b1 swap, short block, trans, head, swap parts, jacksonracing supercharger | egriffith45 | Parts: For Sale/Trade/Wanted | 4 | 01-21-2007 11:06 AM |
| fully built ls swap for sale(complete swap!!! 1500 | turbozcteg | Parts: For Sale/Trade/Wanted | 5 | 10-23-2006 02:17 PM |
| FS: Obd0 B16 Swap Complete EF Swap Mounts, linkage,ecu Cheap | Mr.slippyfist | Parts: For Sale/Trade/Wanted | 10 | 09-06-2006 09:20 PM |
