i have tried searching but have found nothing really useful, so hopefully someone here can help. im swapping in a obd2b b16a2 into a 93 civic si. i have everything i need to bolt in the motor. im just puzzled with the wiring. i have the harness off the sir, but im missing one ecu plug (under dash) and i have the p2t ecu. so im planning on using the harness off the d16z6 and modifying it for the b16.
mods to harness swapping out obd2b dizzy guts for obd1 guts changing injectors to obd1 civic injectors re-pinning obd2b alternator plug to obd1 plug lengthening whatever wires i need to if i do this, can i use the obd2b ecu with a obd1 jumper harness? or do i need a different ecu...like p30 for example? what do i do about that evap sensor on the fuel rail? i would only need to keep it if i used the obd2b ecu right? i appreciate any help |
HS Vendor
Location: 650n Barranca ave #a Covina, Ca 91723 (626) 261-4052
Ride: 00 Civic, 08 Fit, 98 EK
Your best bet is to use an OBD1 ECU, P30, P72, or programed P28... You will save yourself a lot of headache that way.
http://www.SwapShopRacing.com Honda Performance (626) 261-4052 attn: Brian http://www.myspace.com/swapshopr http://www.facebook.com/swapshopracing http://www.twitter.com/swapshopracing |
Administrator
Ride: 318ti, dakota, genesis 2.0t
yup, stick with obd1. its far more friendly to tune with and that's what you car is anyway.
be careful with the alternator... we did that on E's swap, and it simply didn't charge. |
#8 |
Ride: 95 civic sedan ex (dd), 92 caged civic hb (project)
you will get a better response if you start your own post...good luck.
Son Of a Bitch Everythings Real |
#10 |
you have 2 choices:
1: if your not planning on doing any tuning in the future just leave the engine and the harness as is, it should plug into your civic shock tower plug, then get a 0bd1 to 0bd2 conversion harness and use the stock ecu that came with that engine (obd2) 2: as was stated before, if your planning on turbo,nos etc.. then leave the engine harness as is once more and use a obd1 ecu... i have put 0bd2 engines in 92-95 civic without touching the engines harness and just using conversion harnesses to use the ecu the engine came with and never had any issues, the only time i had to switch over harnesses is when i swapped a obd1 b18 in a 99 obd2 civic, and when i did my h2b swapp.. hope that clear it up a bit.. |
#11 |
the harness that came out of the sir wont match up under the hood, its the one piece kind, and even if i ran it through the fire wall, it only has 2 out of 3 plugs for the ecu. if i use a jumper and the stock d16z6 harness and modify it to fit is it still a obd2 motor or 1?
#12 |
ok i stand corrected.. ok your on the right track.. you need to find both engine harness wiring diagrams(just look up the car the engine came out of) so when doing the switch over , you know exactly what sensor is what and where it goes, some times when you have everything off the engine it can get a little confusing,, good to have a reference..
the engine obd is basically whatever harness is on the engine, in your case obd1.. so as was stated before use obd1 ecu , P30, P72, or programed P28 the b16a2 engines will be vtec, but iam not 100% sure if the d16z6 was vtec or not, if not,, dont for get you will have to run vtec wires, knock sensor, vtec solenoid, and vtec pressure solenoid.. if it was vtec your set... and the obd2 engine i swaped into obd1 car was a 99 integra engine in a 92-95 civic cant remember, but that engine does have 3 plugs... Last edited by goldrims; 10-26-2009 at 11:54 PM. |
#13 |
ive taken the harness off my own b16 enough times that i could put it back on in the dark lol. obd2 integras use a 2 piece harness, so if i had one of those it would plug right in, but i have a civic sir harness which means i am going to have to get creative and modify the d16z6 harness. its a vtec harness so i just need to run a knock sensor and possibly EVAP sensor. everything else should be perfect. the obd2b alternator plug has 9 wires just like a obd1 civic, so i should be able to switch that easily,
#15 |
HS Vendor
I have seen them but they are primarly for JDM ECUs. The problem is that the OBD2 system is more complex and even if you adapt the ECU your OBD1 chassis will not support all of the OBD2 functions. Generally people prefer to stick with the OBD1 system & change to a OBD1 ECU P30, P72, or programed P28.
| Jdm Honda B16a2 Dohc Vtec B16a2 92-95 Sir-ii Full Swap | RSS-Bot | Auctions | 0 | 06-02-2008 01:13 AM |
| Jdm Honda B16a2 Dohc Vtec B16a2 92-95 Sir-ii Full Swap | RSS-Bot | Auctions | 0 | 05-26-2008 08:53 PM |
| Jdm Honda B16a2 Dohc Vtec B16a2 92-95 Sir-ii Full Swap | RSS-Bot | Auctions | 0 | 05-19-2008 05:43 PM |
| Jdm Honda B16a2 Dohc Vtec B16a2 92-95 Sir-ii Full Swap | RSS-Bot | Auctions | 0 | 05-03-2008 08:43 PM |
| Jdm Honda B16a2 Dohc Vtec B16a2 92-95 Sir-ii Full Swap | RSS-Bot | Auctions | 0 | 04-26-2008 05:43 PM |
