need help with a b18c swap
Old 05-17-2007, 12:30 AM   #1
ikon671 is on a distinguished road
Default need help with a b18c swap
I'm currently doing a b18c swap into a 99 civic ex, we re-used the civic harnest. any help will be greatly appreciated..
1. Does the b18c have a crank position sensor? because I have on plug on the harnest that has no home right above the alternator.. its old home I believe was to a CPS on the D16..where does this get plugged into?
2. there is a sensor on one of the runners of the GSR intake manifold anf the civic harnest does not have any extra plugs for this sensor.
3. I want to temp eliminate the power steering til we can find a pump can I just cap up the lines or is there more envolved?
sorry for the noob questions but I am not familiar with B series at all...thanks in advance.!!
ikon671 is offline   Reply With Quote
Old 05-17-2007, 04:03 AM   #2
slimtdx is on a distinguished road
ill answer in order...
1. its useless, cant remember exactly what its hooked up too, its early. check the wiring diag. in your haynes manual and compare it to the wiring diag for the b18
2. this sounds like you are referring to the IAB sensor connector which youre old civic harness wont have. youll need to get a vtec harness from hasport or rywire to get all youll need for vtec, iab, and extended o2.
slimtdx is offline   Reply With Quote
b18c swap truoss HYBRID -> EG-EK / DC 4 07-17-2007 09:57 AM
b18c swap now electrical problems! decay138 HYBRID -> EG-EK / DC 3 06-01-2007 12:50 PM
Buying A B18c Type R Swap EG8Demon HYBRID -> EG-EK / DC 17 07-28-2006 11:52 PM
b18c swap in a da mark2k2k HYBRID -> ED-EF / DA 1 07-19-2006 05:07 PM
B18B or B18C swap civicsi94 HYBRID -> EG-EK / DC 20 07-05-2004 06:11 PM
