need help with mini me swap wiring
Old 11-09-2003, 01:11 PM   #1
Kung Foolin'
Ride:  1990 Integra GS
Rep Power: 39 StealthMode has a spectacular aura aboutStealthMode has a spectacular aura aboutStealthMode has a spectacular aura about
Send a message via AIM to StealthMode
i have the wiring harness from the EX that i pulled the head from. would it be better to take out my wiring harness and swap the EX into my car or can i just use my harness from the CX and just add the wires for VTEC?
also, what is the best timing belt to use in this swap? i heard the VX is the best one to use or should i use the EX belt? i heard that my CX is too small.
On a quiet night, you can hear a d-series ninja being born. . .
StealthMode is offline   Reply With Quote
Old 11-09-2003, 01:14 PM   #2
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 541 E_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
use the harness for the EX it will save you some witing bullshit
when i did my minime (D15B7 block , D16Z6 head) i used the timing belt for the D16Z6
МОΛΏΝ ΛΑΒΈ
Old 11-09-2003, 04:42 PM   #3
Kung Foolin'
thanks, do you think i should use the head gasket from the EX or from the VX? (i think, but i can't remember which ones.) one of them ups the compression ratio which adds a couple horsepower, right? i'm not planning on turbocharging this motor, so the higher compression won't really be a problem. also an adjustable cam gear will add a couple too, right? if i advance it a couple degrees?
Old 11-09-2003, 05:25 PM   #4
E_SolSi's Avatar
get the gasket for the D16Y8
МОΛΏΝ ΛΑΒΈ
Old 11-11-2003, 05:16 PM   #5
Kung Foolin'
thanks
how much should i expect to pay for my ecu and dist.?????
ebay would probably be the best bet to find them, right?
99-00 civic Si cluster swap into EF How To (pics0) B18C5James HYBRID -> ED-EF / DA 30 07-11-2007 06:25 PM
auto to manual swap wiring??? thegreat1310 HYBRID -> ED-EF / DA 2 01-19-2004 06:29 PM
JDM ITR swap into 95 GSR - harness/obd wiring? darlix HYBRID -> EG-EK / DC 4 01-19-2004 03:15 PM
Free set of VX wheels wiring my swap. GSR into VX dwnthehatch HYBRID -> EG-EK / DC 3 08-24-2003 05:15 PM
Swap B16a Into Crx, Need Wiring. joeblack HYBRID -> EG-EK / DC 2 04-16-2003 12:32 PM
