gabeybabey
I just put the ZC engine in my 92 civic lx. I had to use my old engine wiring harness because the harness they gave me was reverse because it was from Japan. I got the engine working fine except for the vtec. How do you wire the vtec? I got the OBD1 wiring chart to find out where to put the wires in the computer. The guy I got the engine from said he gave me the right ecu. I put one wire in the computer for the vtec pressure switch and one wire in the computer for the vtec solinoid. I only had one ground wire. I did all that and the vtec doesn't work. I can't stand having a new engine that's not running at its full potential. Please help. I am hoping I don't have to buy a whole new harness because then I'll probably have to take the engine back out to put the new harness on. The guy I got the engine from said all I had to do was put two wires to the ecu and 2 wires to ground. Other than that he didn't know anything else. I'll pay $50 cash to anyone that gives me the solution that works. I need the vtec to work.
Ride: i have 14 cars i drive my sohc turbo ef
wrong forum and zc's dont have vtec neither the single cam or the dual cam are you sure you dont have a z6 they are vtec
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS. |
gabeybabey
I am pretty dang sure my engine is both a vtec and a ZC because ZC is written on the block and vtec is written on the valve cover. Also, written on the computer that the JDM company gave me says sohc. Is it possible that my engine is some special thing only made in Japan?
#5 |
all zc engines are JDM and no they are not vtec maby a mini me thats why the block says vtec and your ecu should not say any thing like zc or any thing it should be a code like a PR4 P30 P28 P06 all diffrent kinds of codes but no zc for a ecu code post up some pics and we can help you out
#8 | ||
Admin with a big stick
Ride: 2003 S2000
All wrong... first of all, wrong forum.
Possibly, but doubt it. Not possible. --- There IS an OBD1 VTEC ZC. Yes, all ZCs are JDM, but there is a ZC that is basically the same as the D16Z6. It's SOHC VTEC, and it does have a legitimate ZC stamp on the block. A VTEC valve cover won't fit on a non-VTEC SOHC block. The spark plugs are on the wrong side of the engine. It is possible that the engine is a mini-me, but you're not typically going to find a mini-me conversion engine from an engine distributor. To the original poster, you might want to check out some of the VTEC wiring threads in the reference section. __________________
#9 |
#10 | |
Newb Engine Swapper
Ride: 94 Civic DX
I just started working with a DOHC ZC the other day. Did you say its SOHC? I beleive they do come Vtec as Calesta said. Do you know how to read the time stamps on the block? If so let me know what year its from. Im comparing stats on all different ZC's. Whats stamped on the block? My DOHC is just 'ZC' Nothing more. When you say you had to use the old harness.. Do you mean the one that attaches to all the sensors ect ect? I just got my head and the hole wire harness off the DOHC and im about to go look up what ODB it is and find some diagrams. I will look for or try to build you a small map on how to wire it into your civic's harness if I find the information. Ic3 __________________
The Devil Finds Work For Idle Hands.... http://www.Ic3INC.net Need anything? Let me know for best price available! |
#11 | |
D16y8 ![]() D16z6 ![]() D16y7 ![]() __________________
Got my swap!!! Needs to be faster.
#12 |
gabeybabey
Ic3
Yeah, my car is a SOHC. I don't know how to read the time stamps on the block. The block says ZC with some other numbers under it. I used my harness from my old stock engine for the sensors. This wiring harness had everything except the vtec plugins because my old engine wasn't vtec. I got a wiring harness with my ZC engine except it was reverse so I took off the plugs that go to the vtec pressure switch and the vtec solinoid. I plugged them in the ecu like an OBD1 wiring chart said, but that didn't work. If you could get me a small wiring map that might help me that would be great. |
#13 | |
Ride: 2003 S2000
![]() Ic3, all ZCs will only have "ZC" stamped on the block. Anything else is NOT a true ZC. __________________
#14 | |
Newb Engine Swapper
Ride: 94 Civic DX
Anyone else read threw this guys posts and realize that 90% of what he says is bullshit? Or is it just me :S Some of the information this guy has gave to people could be deadly.. I suggest removal with the big ol... BOOT Ic3 __________________
#15 |
Ride: 2003 S2000
Everyone has to learn somewhere- we can't go around banning everyone just because they don't know everything- but you're right, this kind of information dispersal is dangerous.
| VTEC v6 engine weight??? | ctgman | Accord | 1 | 06-13-2007 11:34 AM |
| Assembling an LS/VTEC | pissedoffsol | General Tech Articles | 1 | 06-04-2004 11:17 AM |
| need vtec ecu for manual d15b engine | micmac | Engine Building | 1 | 08-23-2003 02:31 PM |
| D16z2 Engine - Would Like To Make It Vtec | coupe216 | HYBRID -> ED-EF / DA | 18 | 05-28-2003 03:57 PM |
