Need a smaller power steering pulley....rubbing on headlight
Old 10-29-2009, 12:04 AM   #1
Rep Power: 0 CK4500 is off the scale
Default Need a smaller power steering pulley....rubbing on headlight
I resently comepleted a block swap on my EK hatch.
I had a B16A2 and swapped out the block for a B18C1. I am running a Vortech Supercharger, and I ended up having to re-engineer all of my supercharger mounts.
With the added height of the new block, my power steering pulley is in the way for my to put my headlight back in. It will make contact with my headlight adjustment gears. So I can't just rework the back side of the head light.
I'd like to try to keep my power steering.
Does anyone know of a smaller pulley that will fit?
CK4500 is offline   Reply With Quote
Old 10-29-2009, 12:08 AM   #2
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Look for some underdrives- might also want to look into lowering your engine mounts to drop the engine a bit too if you want to go the cheap route.
Old 10-29-2009, 12:10 AM   #3
Lowering the engine? How would I do this cheaply!?
Old 10-29-2009, 12:12 AM   #4
Calesta's Avatar
Ride:  2003 S2000
Washers, custom spacer... it's a bit "ghetto" but it can work.
JDM Honda Civic Power Steering Pump with AEM PULLEY RSS-Bot Auctions 0 04-28-2008 03:33 PM
Tru-Power Pulley Kits 97-01 Integra Type-R (TRU-POWER P RSS-Bot Auctions 0 03-11-2008 07:53 PM
94-95 Mustang Cobra Gt Chromed Power Steering Pulley NR RSS-Bot Auctions 0 12-06-2007 10:53 PM
Power Pulley Kit calvin Engine Building 1 01-12-2004 11:23 PM
Jrsc With 9lb Pulley How Much Power tomtom Forced Induction 2 02-17-2003 12:01 AM
