Need you input!!
Old 10-15-2007, 09:06 PM   #1
Rep Power: 5 u n v me23 is on a distinguished road
Default Need you input!!
I'm thinking about upgrading my camshaft, cam gears, ecu, flywheel, and clutch. Now from my understanding, ACT makes really good kits and so do hondata. I have a B18C motor and tranny.
So far I have...
Skunk2 intake manifold
hondata gasket
skunk2 throttle body
DC Sports 4-1 header
Greddy Evo exhaust
AEM Cold Air Intake
AEM Fuel Rail
AEM Fuel Reg.
Planning to Get..
skunk2 camshafts (not sure which stage)
skunk2 cam gears
What stages do you all think? Dont really know the break down in stages.
Thanks for your help
u n v me23 is offline   Reply With Quote
Old 10-15-2007, 10:50 PM   #2
Honda Master Technician
norcalgsr's Avatar
Ride:  88 Prelude Si and a CBR 600 Hurricane
Rep Power: 21 norcalgsr is a jewel in the roughnorcalgsr is a jewel in the roughnorcalgsr is a jewel in the rough
myspace
If you're not upgrading valve springs stage 1 is as aggressive as you're going to be able to get without running a risk of floating the valves and breaking something. Even with the stage 1 cams, considering the fact that the GSR only has single springs on the exhaust side, you may want to upgrade the valve springs anyway or if not definitely don't raise the redline above stock. With the mods you already have done if you get a set of valve springs/retainers and go for the Skunk stage 2 cams you will make some serious power over the stage 1's.
As far as the clutch/flywheel go I like Exedy products and have always had good luck with them, but I've heard a lot of good things about ACT as well. I just don't feel the need to stray away from something I know works great for me personally.. hopefully some others can help out in that area. Although if you are looking for another quality brand I would urge you to look into their products as well. Their stage 1 clutch has something like 40% increased holding power over a stock clutch while keeping the clutch effort reasonable. Drivability is pretty close to stock once you get used to the higher pedal pressure..
norcalgsr is offline   Reply With Quote
Old 10-15-2007, 11:13 PM   #3
ok.. would I have to upgrade the forged valves as well?
Old 10-15-2007, 11:49 PM   #4
norcalgsr's Avatar
myspace
No if you get the Skunk2 springs you will be just fine with the stock valves.. and you can change the valve springs with the head still on the block..
Old 10-16-2007, 12:02 AM   #5
So Should I go with turner or pro series camshaft?
Tuner
Stage 2: Street/Race cam designed for engine with free-flowing intake and exhaust tracts, increased compression, and upgraded valvetrain.
Pro-Series
Pro 2: High Lift Street/Race cam designed to optimize mid-range and top end HP and TQ. Peak power is increased and power band is moved 700rpm higher than Pro 1. Pro-Series valvetrain required.
Old 10-16-2007, 11:49 AM   #6
dtob's Avatar
Rep Power: 11 dtob is an unknown quantity at this point
Tuner
Pro-Series
All depends on what you want. Tuner series retains a stock idle and requires less tuning to run them. Also the tuner series would keep your current fuel mileage. They retain the stock off vtec cam profiles so vtec hits harder.
The pro series have different off and on vtec cam profiles so extensive tuning is required to even get the car to idle. The idle is lopy and fuel mileage would take a hit.
dtob is offline   Reply With Quote
Old 10-16-2007, 11:56 AM   #7
Ken Korn Karn
Ride:  '96 EK Hatch/ '98 LS1 Trans Am WS6
Rep Power: 5 SeVeNisOnE is on a distinguished road
I would stick to the tuner spec Skunk2 cams. The other cams are too aggressive for daily driven vehicles unless you are going to get the car properly tuned and still be willing to give up some drivability. Anything more than the stage 1 tuner cams would recommend you upgrade the valve springs and retainers in order to take advantage of the higher lift profile on those cams. If your not willing to upgrade the springs then just stick to stage 1 cams. I had the stage 2 cams on my car before and the power is felt in the higher rpm ranges which is why I recommend you change springs. My redline was also bumped up to 9k. I wouldn't go that high on OEM springs for too long.
ACT makes great products. I've never had a problem using them. I recommend their StreetLite flywheel and their Heavy Duty Pressure Plate with Performance Street Disk. Good combination for street use.
Silver '96 EK Hatch | Carbon Fiber Hood/Wing | Front/Rear Mugen Lower Lip | B18C Swap | PR3-2 Head | K&N CAI | Ported & Polished TB | Skunk2 IM | AEM Fuel Rail & Regulator | A'pexi WS2 Exhaust | Test Pipe | DC Sports Race Header | Skunk2 Cam Gears | RC 450cc Injectors | Hondata S200 | Eibach Sportline Springs | 15" Bronze Rota Grids | MSD Plug Wires | NGK Iridium IV Plugs
SeVeNisOnE is offline   Reply With Quote
Old 10-16-2007, 01:43 PM   #8
dtob's Avatar
Old 10-17-2007, 05:20 PM   #9
Grandpa
88blacksi's Avatar
Rep Power: 7 88blacksi is on a distinguished road
Skunk2 is okay. Toda KILLA CAMS are the best. But my idle is jumping everywhere I dunno if want this, but overall the best i have bought.
88blacksi is offline   Reply With Quote
Old 10-17-2007, 05:39 PM   #10
norcalgsr's Avatar
myspace
There isn't one best cam for all cars it all depends on the rest of your engine package!
Old 10-18-2007, 12:28 AM   #11
dtob's Avatar
Ya but I wouldn't get the toda killers. Way too crazy for a dd.
Old 10-18-2007, 01:57 AM   #12
norcalgsr's Avatar
myspace
I wouldn't either that would be a retarded choice for a street driven car.. especially considering you have to have super high compression/redline to get any real benefit from them. Put those on a stock valvetrain and have fun bending valves..
Old 10-18-2007, 02:02 AM   #13
AHHVTEC's Avatar
if its gona be a dd stick with a stage 2,, and i would upgrade to a better header
F20B Input import_zero Engine Building 4 06-22-2007 03:00 PM
Noid Light not flashing delsolh22 HYBRID -> EG-EK / DC 11 02-22-2007 07:40 AM
Which B series header should I buy? Help, input needed!!! 94redhatchback NYC General Tech and Maintenance 2 02-15-2007 05:24 PM
88+ ECU Error Codes pissedoffsol Reference Materials 1 05-19-2005 01:03 PM
wtb: 91 teg input shaft joesefcivic Parts: For Sale/Trade/Wanted 0 01-20-2004 03:41 PM
