Ride: 1991 civic dx
Im planning doing a b18a1 in my 2000 ex coupe.. I have the block and head, still need tranny, and everything else. I jus had a few questions. And yes i know the motors obd0 and from 1992 but i got it for 80 $$ soo who would pass that up. Anyways
1. Can i use the altinator and or starter from my d series? 2. In order for. Me to pass inspection cant i just get obd2 or 1 dizzy and altinator and run a obd2 computer? Thank you all on hs for helping out |
Ride: '92 Hatch si w/B16 (wannabe EG6)
I am pretty sure that you cannot put an older motor in your car where you live and pass
inspection but I live in the strictest state. If you convert it all to run OBD2 and have no CEL's and motor burns clean....you could just go smog it but the motor says B18A on the block. Might work though. You need a few things for sure. (you can do OBD1 but i say OBD2), ECU, Dizzy, Alt, mounts, axles, the EX engine harness (without the VTEC...duh). Not sure if the plugs are the same but I think its covered with the dizzy and alternator switch. I think if you change the intake to a B18B....you'll get 10 extra hp. If this motor is JDM...the intake is different anyways (no Evap. Purge Sol.) I know this was a cheap thing intitially but its a venture of research and labor to get it done. Oh...and I think I think you need to use the injectors too....like I said...just get a OBD2 LS intake...hell the whole top end if you can find one cheap enough. __________________
"Meow, you know how fast your were going back there?" http://hondaswap.com/hybrid-eg-ek-dc...si-b16-286581/ |
Ride: 1991 civic dx
Thanks man. All they do is the obd2 plug
Correct me if im wrong tho Obd1 dizzy, intake manni, alt and starter And 96-98 99-00 jumper harness with a 00 ls computer |
#7 |
LMAO! WTF for sure.
There are a few ways to approach putting this motor into your car. One is going OBD1 conversion and use a jumper harness for an OBD2-OBD1 and have a OBD1 ECU. You say the car is a 2000 so why do you need a conversion if you are using a 2000 LS ECU? I'm confused on your post The other way I know is to convert everything on that motor to OBD2 (Dizzy/Al /Injectors/Intake Man/ECU) But my true opinion is this motor of yours with a 2000 civic is (at best) a spare bottom end with some spare parts. The top end is okay and you could spend $$$ and have it ported/polished and such but that's just not the 'smart' move to make. Putting this motor in your car will cost you at least $700-800 bucks after you buy a transmission (at least $200 more if you want GSR trans), Intake manifold, dizzy, alt, axles, ECU, shift linkage, mounts and other misc parts. Then you add the cost for new timing belt, water pump, maybe oil pump, cam seals, dizzy cap/rotor, spark plugs, etc etc. (and I think it is pretty inexperienced to think you can gamble on those parts being 'okay') That adds to around $250 maybe a little more. Or you can buy an OBD2 B18B and throw it straight into your car....later turbo it and have an extra bottom end...and head. But if spending a minimum $1000 to convert this into your car seems too excessive for you and your current motor set up (like 'if it ain't broke, don't try to fix it') I would come up with a new plan. I don't know how comfortable you are with these mechanical conversions and this could become a big headache. __________________
#8 |
Ride: 1991 civic dx
no i know. im not planning on buildiung it yet. i just want a stock ls for now. BUT one more question. i need to pass emissions. how do i do this with a obd0 motor in a obd2 car?! obd2 ls ecu? with a jumper harness REP + bro
#9 |
not possible to pass visual (like I said earlier)
But you could get lucky if the place you take it to doesn't look to see its a B18A.... If he does see it and knows....it WILL NOT pass....PERIOD So I think its a bad move....maybe get an OBD0 car? (hatchie or CRX?) I truly think that the swap is a bad idea but its possible THIS WILL COST A MINIMUM $1000.00 (Get a full swap for $600-800 more) __________________
#10 |
And the full swap WILL pass inspection (not sure if you have to REF though)
#11 | |
Ride: 89 CRX SI (LS)
just cut the wires to your solenoid and run a new signal wire from an accesory in your fuse panel and run a ground that way when you turn your car on bang vtec. Maybe someone knows the colours of the wires to tell you which is ground and power. Let us know how it turns out. Last edited by pappaj; 06-28-2009 at 08:21 PM. |
#12 |
No! Super bad idea
VTEC lobes on the cam are for high rpm.....non-vtec lobes on the cam are for low rpm No need to Eff with Honda engineering/wiring......dumb idea Some ricers think that VTEC coming on at 4300 rpm is good too......no. VTEC is a smooth transition...not to say it needs to stay stock but being drastic about the engagement point is stupid. Its not a video game boost button. __________________
#13 |
Ride: 1991 civic dx
Ok the only thing they do wen my car gets inspected is they plug it in the obd2 port. So i cant use my b18a1 motor, get a obd1 dizzy alt inkectors and starter then buy a obd1 to obd2 jumper harness and run a obd2 ls computer. Correct?
#15 |
Jumper harness is at the ECUplugs....so no you need OBD2 ECU and other stuff....thats how I'ddo it but if you find other info and feel comfprtable with the mix of OBD2 and OBD1 stuff...go for it
Either way...your spending a cool grand __________________
#17 |
Alternator and injector plugs too.
A grand.....that's the $1000.00 you'll spend after that stuff and the mounts/axles/shift linkage Oh....and the transmission __________________
#19 |
Here's a link to a guy on this site selling a COMPLETE OBD2 LS intake
FS: Rota GT-3's with tires, a couple tachs. few other things __________________
#22 |
Hard wire VTEC....its just really really stupid. Idiotic. Like what idiots do to their cars. Seriously
If your VTEC isn't working....how the hell is wiring up to be on all the time any beneficial to the problems the engine has now? Sorry to be a butthead about it but this thread isn't even about a VTEC motor...it was about some guy (who has now disappeared) who wanted to put a motor that is at least 8yrs older then his car into his 2000 Civic. It was a B18A which is NON-VTEC __________________
#24 | |
Brutal Moderator
Ride: 97 Integra LS Coupe
2.) Hard-wiring VTEC is a stupid idea. It's supposed to come on at a certain RPM. That's the way it works. You need to wire it in correctly and use a proper ECU. 3.) You're an idiot. Srsly. __________________
| D-Series headers, CRX lights, Nearly new CRX Battery, other D-series parts! | Dasfinc | Parts: For Sale/Trade/Wanted | 13 | 06-14-2009 01:11 AM |
| CXRacing Intercooler 29x9x3 Civic D16 D-Series B-Series | RSS-Bot | Auctions | 0 | 06-02-2009 01:03 PM |
| will any b series clutch and flywheel work in any b series tranny? | labe lincoln | HYBRID -> EG-EK / DC | 2 | 04-02-2009 09:42 PM |
| CXRacing Intercooler 29x9x3 Civic D16 D-Series B-Series | RSS-Bot | Auctions | 0 | 03-24-2009 10:36 PM |
| CXRacing Intercooler 29x9x3 Civic D16 D-Series B-Series | RSS-Bot | Auctions | 0 | 11-13-2008 04:36 PM |
