| | #1 |
| Senior Member | well guys these weekend i get a little be crazy and i decided to do a swap on my car i have a EG stock and my friend was give away his LS engine so i decide to do it everything was mad easy fo r be my first swap everything was bolt on even the wiring harnes the engine came out of a 1998 LS 98000 MILES THE ONLY THING WAS the at the tranny has a little a wrecled noisy so i will need one soon but everything is perfect ..... anothe here i get a little confuse the AC bracket its to big for the compresor that i have its any bracket that fit on the car and i can still use my AC compresor i dont wannt to change compresor all that i want is a bracket that fit my compresor ..... thank you for your help and believe me these swap has power i love so far |
| | #2 |
| Senior Member | get you the AC bracket from Hasport for B series swaps into a D series chassis. Its like $165 which isnt bad. you will be able to use your stock AC compressor on your new LS motor. |
| | #3 |
| Senior Member | i was searching and i found if i use a del sol vtec 1994-97 ac bracket it willl fit perfect its that tue |
| | #4 |
| Senior Member | i am not sure... i think you can get that bracket from honda and it may fit. i just swaped a B16 into my EG and was able to retain P/S by using the B series pump and bracket and the P/S hose and tank neck from my D series. the AC was different though. I couldn't use my compressor with the AC bracket on my B series. my advice: get the compressor and stuff from your friends LS Teggy and use your D series lines. could save you some money. |
| | #5 | |
| Senior Member | Quote:
| | #6 |
| Senior Member | ahhh.... well i dont know then. i know my motor is the JDM equivalent of the USDM del Sol motor and the AC bracket didn't work for me. maybe it will work for you. i would junk yard search first though because those cars have to be around and the bracket isn't hard to remove. You'll need a 17mm socket that is 1/2 inch drive and a decently long socket wrench, 1/2 inch drive, to make things easy. you may also need a 14mm and a 12mm if the AC compressor is still on the motor as well. good luck and let me know what bracket fits because I am also trying to retain AC |
| | #7 |
| TK - CivNation | The AC bracket from a CRV is a cheaper alternative, I forgot which year, but if you order it straight from one of the honda parts companys online you can get it much cheaper than getting the del sol ac bracket. I paid $84 shipped for mine. Maybe that might help. And yes they are the same exact mount. |
| | #8 | |
| | #9 |
| TK - CivNation | the delsol ac bracket and the (years not sure, basicly the ones with the b20 in them) crv ac bracket are the same, have the crv one and its the same size, mounting holes and everything to the delsol one. |
Similar Threads | ||||
| 93 Del Sol Swap | del sol | HYBRID -> EG-EK / DC | 4 | 10-31-2007 04:32 PM |
| need some info on swap | gin | Civic and del Sol - EG and EK | 0 | 09-16-2006 08:22 PM |
| need info on b18 swap | gin | Civic - EP, FA, FG | 1 | 09-13-2006 08:15 PM |
| Del Sol S D15B7 to D16y8 swap question | oakley2002@cox.net | HYBRID -> EG-EK / DC | 1 | 01-21-2004 12:32 PM |
| Swap Prices Are Up | hatchboy | Parts: For Sale/Trade/Wanted | 9 | 05-26-2003 04:49 AM |
