Newly swaped engine wont start.....
Old 01-26-2006, 07:02 PM   #1
Rep Power: 10 prettyinpink is off the scale
Send a message via AIM to prettyinpink
[img]style_emoticons/<#EMO_DIR#>/unsure.gif[/img] ok ok so everyones going to read this and think the obvious but all the obvious has been checked!
b18a (91 int ls) into 92 cx hatch... has good compression, spark, fuel, crank pulley itself turns w/ no problem, battery, alt, and starter good... ground good... but stil wont start, it just turns over but wont go all the way(its a strong, good sounding crank if that makes any difference)... anything stupid or something else that should be checked? i fell pretty stupid asking but i have asked professional shops and technicians and no one can figure it out.. any ideas please? i know it has to be something right in front of our face.. but we cant seem to figure it out. thank u muchly.
prettyinpink is offline   Reply With Quote
Old 01-26-2006, 08:37 PM   #2
Rep Power: 9 adamsjm5 is off the scale
What is your fuel pressure?
<div class='quotetop'>QUOTE(prettyinpink @ Jan 26 2006, 07:02 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
adamsjm5 is offline   Reply With Quote
Old 01-26-2006, 10:22 PM   #3
FüK-VTEC
civicious's Avatar
Ride:  07 Nissan Frontier, 90 CRX Si, 06 ZX6R racebike, chopped-out 02 Yamaha V-Star
Rep Power: 189 civicious has a reputation beyond reputecivicious has a reputation beyond repute
civicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond repute
Send a message via AIM to civicious myspace
Is it getting spark? Fuel?
Make sure you're getting fuel to the fuel rail, and check to see if you're getting spark. If you aren't getting fuel it's either a dead main relay, bad ECU, or a ground. If you aren't getting spark, check your plugs, plug wires, and if everything checks out, get another distributor.
CMRA #265
http://www.myspace.com/civicious
AIM: greyfades
civicious is offline   Reply With Quote
Old 01-27-2006, 04:00 PM   #4
Kung Foolin'
Ride:  1990 Integra GS
Rep Power: 39 StealthMode has a spectacular aura aboutStealthMode has a spectacular aura aboutStealthMode has a spectacular aura about
Send a message via AIM to StealthMode
[img]style_emoticons/<#EMO_DIR#>/withstupid.gif[/img] That's an OBD0 motor that you swapped into an OBD1 car. Make sure you have the right ECU, and see if your distributor is working properly.
On a quiet night, you can hear a d-series ninja being born. . .
StealthMode is offline   Reply With Quote
