No spark problem with b18b1 swap
Old 12-05-2007, 08:34 PM   #1
Rep Power: 0 extacyisgood4u is on a distinguished road
Default No spark problem with b18b1 swap
i bought a 99 hatch dx with the motor and tranny (95 b18b1) already swapped in it, but no wiring. i used an SI harness to wire it (some connectors werent used cause of no AC and PS). the car started at first for a lil, but not anymore. at first i thought it was the ignition (car came with push button). i changed it, and no good. then i thought it was the ECU (which is rewired to OBD1), but it worked with my friends EK civic. then i thought it was the distributor, but that wasent it either cause i changed 2 already and still dont start. there is a crank but no spark. im really getting frustrated and already thinking of selling the car cause of that. can anybody tell me what else it can be? wiring problem? thanks.
extacyisgood4u is offline   Reply With Quote
Old 12-05-2007, 09:11 PM   #2
knuteiriktveiten's Avatar
Ride:  95 DX with built/boosted gsr swap and a 90 Hatch with a LS Swap and now a '00 Trans Am
Rep Power: 13 knuteiriktveiten is a jewel in the roughknuteiriktveiten is a jewel in the roughknuteiriktveiten is a jewel in the roughknuteiriktveiten is a jewel in the rough
Send a message via MSN to knuteiriktveiten myspace
you sure its not a fuel problem?
knuteiriktveiten is offline   Reply With Quote
Old 12-05-2007, 10:32 PM   #3
well we had a fuel problem. the thread under the fuel filter was bad so we changed some of the fule line with the filter. u think we might be losing fuel pressure? i might have to double check that cause thats a really good point. but we pulled out the plugs and no spark. any other suggestions? maybe wiring problem?
Old 12-06-2007, 08:14 AM   #4
maybe i missed a ground wire somewhere? can that also be it? does anybody know the critical grounding points on a b18b1 to ek hatch swap? thanks
Old 12-11-2007, 07:50 PM   #5
Rep Power: 5 toqeer1986 is on a distinguished road
check grounds but i ran in to the same prob no spark and all wired up to obd1 spec turned out to be my ecu now im running a p28ecu chipped with type r map try a diff ecu but make sure u check the icm wire going to the dizzy as that sends the signal for the spark plugs to spark make sure u got ground on ur thermostat as well and engien and tranny hope this helps
http://img115.imageshack.us/slidesho...050297vhr.smil Chek my b18c4 swap pics
toqeer1986 is offline   Reply With Quote
Old 12-12-2007, 04:27 AM   #6
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Rep Power: 43 LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
check your fuses first. Under the hood there is a relay box. check all the fuses, especially the ECU fuse. If that all checks out ok, try doing a voltage drop test. Find out where your losing voltage. (that is if there is no spark). Try putting new wires, plugs, cap and rotor as well if the previous rec's dont work out.
eg hatch (jdm b16) sold
1999 Yamaha YZF R6 (modded)
http://hondaswap.com/engine-building...ow-pics-102486 sold
LS_VTEC is offline   Reply With Quote
Old 12-12-2007, 04:29 AM   #7
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
he did say he got it running before, so that pretty much eliminates grounds and wiring... unless wires were corroded or damaged. but I think your problem is in the starting system.
Old 12-12-2007, 07:51 AM   #8
yeh i think the wiring would be out of the options check the coils in the dizzy see if they are bad or just borrow someone elses but i thing its probs the ecu or the dizzy itself . the fuel relay has nothing to do with the car giving spark at the spark plugs
check the wire from pin A21 going to the dizzy icm module. check the link below for the wiring circuit its a pdf file if you dont have anything to open it with use FOXIT its faster than acrobat. hope this helps
http://www.honda-civiconline.com/dat...onnections.pdf
Old 12-12-2007, 02:28 PM   #9
decapitates emo kids
UNDR8D's Avatar
Ride:  A hard bargain
Rep Power: 78 UNDR8D has a reputation beyond repute
UNDR8D has a reputation beyond reputeUNDR8D has a reputation beyond reputeUNDR8D has a reputation beyond reputeUNDR8D has a reputation beyond reputeUNDR8D has a reputation beyond reputeUNDR8D has a reputation beyond reputeUNDR8D has a reputation beyond repute
Originally Posted by toqeer1986 View Post
the relay is just for the fuel pump so thats got fuk al with spark cuz if tryed it lolz but i came into that prob and it was the ecu
what?
UNDR8D is offline   Reply With Quote
Old 12-13-2007, 02:03 AM   #10
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Originally Posted by UNDR8D View Post
what?
LOL
Old 12-14-2007, 03:05 PM   #11
ooopz lolz typo :P
Problem with GSR swap, Maybe spun bearing? drtysohc General Tech and Maintenance 15 12-05-2007 09:52 PM
Injectors problem for b16 swap in a 89 crx si mikester1222 HYBRID -> ED-EF / DA 17 06-08-2007 02:06 AM
Honda Spark Plug Tech Guide JDMEG-6 General Tech and Maintenance 2 01-26-2007 09:27 PM
crx with b swap NO SPARK russianswty HYBRID -> ED-EF / DA 14 01-24-2007 09:16 PM
90 CRX DX b18b1 swap axles and controol arm problem nathansnation Civic and CRX - EW 3 10-17-2006 01:32 AM
