no vtec due to good oil???
Old 10-09-2003, 03:50 AM   #1
Rep Power: 14 allgo is off the scale
i have a stock b16 motor and running on synthetic oil but not vtec. i have read somewhere that if u have a stock motor or low compression motor, dont use synthetic oil. is this true??????????????? also, why is my speedometer flick up and down when i drive normal??
allgo is offline   Reply With Quote
Old 10-09-2003, 10:37 AM   #2
Rep Power: 28 rsaeini is off the scale
check your speed sensor for that. it's located on your tranny, near where the passenger side axle goes into it.
mine did that before cuz i got some coolant on it while doing my swap. i took the plug out, dried it, held a blow dryer(on cool setting) on it for like 15 minutes and it fixed the problem.
"let those who judge me burn in hell until their Hondas are repossessed" - ME 1.6-1.8
rsaeini is offline   Reply With Quote
Old 10-09-2003, 10:49 AM   #3
Rep Power: 15 uconn1150 is off the scale
I think that if the VSS is bad/going bad it will affect VTEC
"...as a result of your seeking, you cannot find..."
uconn1150 is offline   Reply With Quote
Old 10-09-2003, 10:52 AM   #4
also, do you have a check engine light on?
when you get up into the rpm range when your vtec is supposed to kick in, does the sound change slightly?
what car is this in(year/model/trim level) ?
what ecu are you using?
Old 10-09-2003, 10:59 AM   #5
SLA
Rep Power: 16 SLA is off the scale
Send a message via Yahoo to SLA
How many miles are on your B16?
The only replacement for displacement is technology!
Ride: 1995 Civic Dx in desperate need of a heart transplant!
SLA is offline   Reply With Quote
Old 10-09-2003, 12:47 PM   #6
FüK-VTEC
civicious's Avatar
Ride:  07 Nissan Frontier, 90 CRX Si, 06 ZX6R racebike, chopped-out 02 Yamaha V-Star
Rep Power: 189 civicious has a reputation beyond reputecivicious has a reputation beyond repute
civicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond repute
Send a message via AIM to civicious myspace
i've seen synthetic oil make vtec not work before...
just use Royal Purple. it's the bomb diggity.
CMRA #265
http://www.myspace.com/civicious
AIM: greyfades
civicious is offline   Reply With Quote
Old 10-09-2003, 01:01 PM   #7
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
Correct, as you can't just rev it to 7000rpms in neutral and hit vtec, it needs the speed sensor too. As far as synthetic keeping it from engaging vtec, hmmm, I wouldn't think so, but some brands could I guess.
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 10-09-2003, 01:03 PM   #8
that's not true. the type of oil you use doesn't determine if the vtec is enabled or disabled. i was under the same impression for a little while but i started doing some homework on the sudject and discovered the following.
the biggest reason why vtec doesn't work and you don't get a cel is either because you don't enough oil in there, you're not getting enough oil pressure, or the screen inside your vtec solenoid is clogged up a bit.
in a situation where the car is running fine under 5500rpms but vtec doesn't work and no check engine light is coming on, that screen i'm talking about is more than likely clogged up. when that screen is clogged up it doesn't allow for enough oil/oil pressure for the vtec to kick in.
PS- Royal Purple is good and all but i will stand by my Castrol full Synthetic oil everytime.
Old 10-09-2003, 01:05 PM   #9
Originally posted by 92b16vx+Oct 9 2003, 09:01 AM--><div class='quotetop'>QUOTE(92b16vx @ Oct 9 2003, 09:01 AM)</div><div class='quotemain'> <!--QuoteBegin-uconn1150@Oct 9 2003, 03:49 PM
Correct, as you can't just rev it to 7000rpms in neutral and hit vtec, it needs the speed sensor too. As far as synthetic keeping it from engaging vtec, hmmm, I wouldn't think so, but some brands could I guess. [/b][/quote]
i didn't know the speed sensor affected vtec.
i think i might do some reading about this.
&quot;let those who judge me burn in hell until their Hondas are repossessed&quot; - ME 1.6-1.8
Old 10-09-2003, 01:12 PM   #10
FüK-VTEC
civicious's Avatar
i stand corrected.
CMRA #265
AIM: greyfades
Old 10-10-2003, 12:02 AM   #11
i have a 95 vx with a b16. i plug up the vtec wires so it should work but it doesnt. i cleaned the solenoid sceen so that is clean. all i am getting on cel is 10 and 41 which would not effect vtec. i am dropping a bit of oil though but not too much. i have oil on my vavle cover which i dont know where its coming from but i think i just need a new seal for the vavle cover. im revving up to only 6000 rpm right now due to the fact that i have no vtec. i have straight pipe with no cat so i hear a bit of air pushing through my stock muffler making a rattle sound that sounds like vtec. NEED ALOT OF HELP!!!!! THANKS FOR HELPING SO FAR.
Old 10-10-2003, 11:00 AM   #12
does anyone have a manual handy that can tell him what those codes are for. i'm at work right now so i can't tell you.
also, when you're getting a cel your vtec won't work so get those fixed and it should start working again.
as far as the valve cover, definitely get a new seal for it and make sure you're tightening it down correctly.
Old 10-10-2003, 11:40 AM   #13
Rep Power: 16 ChrisSiR is off the scale
10 = intake air temp....
are you sure your getting a 41? and not a 4 and a 1?
i see no 41 for a code in my manual...
it also says "if codes other than those listed above are indicated, count blinks again. if it is infact blinking unusual codes, substitute with a known good ecu and recheck. if the indicator goes away replace original ecu... the check engine warning light and ecu led may come on, indicating a system problem when in fact there is a poor intermitint electrical connection... first check all electrical connections, clean and repair if necissary. if check engine waringing light and led stays on, replace ecu"
also, i have never run into ANY problems w/ using synthetic oil...... ive used Syn Mobil 5/30 since the day i baught it... all my issues have been because of poor wireing...
<span style=\'color:blue\'>1988 Crx Dx (<a href=\'http://turbogizzmo.com/gallery/view_album.php?set_albumName=Crxpic s\' target=\'_blank\'><span style=\'color:red\'>Dubbed the Go-Kart</span></a>) <span style=\'color:red\'>?hp 178tq</span></span>
<a href=\'http://Coracin.net\' target=\'_blank\'>CoRacing.net</a>
<span style=\'font-size:13pt;line-height:100%\'><span style=\'color:blue\'>I swear, all girls should come with their own carfax report...</span></span>
ChrisSiR is offline   Reply With Quote
Old 10-10-2003, 02:09 PM   #14
Rep Power: 16 dmmd3 is off the scale
Send a message via AIM to dmmd3
actually 10 being temperature would affect vtec since there are 5 things that must be right for vtec to engage which are 1.normal operating temp 2. throttle position 3. wheels must be moving forward 4. rpms and 5. safe oil pressure levels.
dmmd3 is offline   Reply With Quote
Old 10-10-2003, 02:25 PM   #15
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
41 is heated o2 sensor.
95 CX|B16A2
Old 10-10-2003, 02:28 PM   #16
Originally posted by 92b16vx+Oct 10 2003, 01:25 PM--><div class='quotetop'>QUOTE(92b16vx @ Oct 10 2003, 01:25 PM)</div><div class='quotemain'> <!--QuoteBegin-ChrisSiR@Oct 10 2003, 04:40 PM
41 is heated o2 sensor. [/b][/quote]
i guess i should have asked what motor, i show no 41 for a b16a Sir1
im assuming this is OBD2 then ::
Old 10-10-2003, 02:31 PM   #17
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Originally posted by ChrisSiR+Oct 10 2003, 07:28 PM--><div class='quotetop'>QUOTE(ChrisSiR @ Oct 10 2003, 07:28 PM)</div><div class='quotemain'>
im assuming this is OBD2 then :: [/b][/quote]
1994 Helms Del Sol, B16A3, Page 11-44 code 41, heated oxygen senor (HO2S) heater.
95 CX|B16A2
Old 10-10-2003, 02:59 PM   #18
Originally posted by 92b16vx+Oct 10 2003, 01:31 PM--><div class='quotetop'>QUOTE(92b16vx @ Oct 10 2003, 01:31 PM)</div><div class='quotemain'>
1994 Helms Del Sol, B16A3, Page 11-44 code 41, heated oxygen senor (HO2S) heater. [/b][/quote]
my aplogy's, i just saw b16.... the only manual i have is for the obd0 b16
Old 10-11-2003, 04:30 PM   #19
thanks for all the replies. so vtec is effected by 10 and 41??? i have two ecu, p28 and p30 and getting same codes for both now. wi th the p28 i can rev motor up but with p30, i can only rev up to about 3500 rpm and then it all cut fuel.
no vtec due to 10 and 41????? or is it due to oil on my vavle cover????
thanks all of u guys for helping
Old 10-11-2003, 04:45 PM   #20
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
41 won't effect vtec, it just throws a CEL, but no limp mode.
95 CX|B16A2
Old 10-11-2003, 04:54 PM   #21
Rep Power: 17 haccord141 is off the scale
Send a message via AIM to haccord141 Send a message via MSN to haccord141 Send a message via Yahoo to haccord141
you said it castrol rocks
<u><span style=\'font-family:Courier\'>Mind your own damn business, b*tch!!!!!</span></u>
.3K Club (Yea Baby!!!)
Check out my accord I finally took some pics!!! PM me to tell me what you think of it:
<a href=\'http://www.hondaswap.com/gallery/browse.php?album_id=862\' target=\'_blank\'>http://www.hondaswap.com/gallery/browse.php?album_id=862</a>
haccord141 is offline   Reply With Quote
Old 10-22-2003, 07:11 PM   #22
Rep Power: 15 civicruleshatches is off the scale
Originally posted by rsaeini+Oct 9 2003, 09:37 AM--><div class='quotetop'>QUOTE(rsaeini @ Oct 9 2003, 09:37 AM)</div><div class='quotemain'> <!--QuoteBegin-allgo@Oct 8 2003, 11:50 PM
mine did that before cuz i got some coolant on it while doing my swap. i took the plug out, dried it, held a blow dryer(on cool setting) on it for like 15 minutes and it fixed the problem. [/b][/quote]
just a thought but if the ecu is not getting the correct speed readings wouldnt that keep vtec from engauging also. try cleaning it like posted and c if that helps
civicruleshatches is offline   Reply With Quote
Old 10-23-2003, 03:18 AM   #23
Rep Power: 20 97CTR is off the scale
fix your cel 10 and your vtec should work. test the sensor, check wiring.
97 ex coupe
Wire tuck in progress....
97CTR is offline   Reply With Quote
Vtec Solenoid Troubles RandomTask76 HYBRID -> EG-EK / DC 5 05-20-2009 01:05 AM
VTEC & Wireing an203888 ECU's, Electronics, and Tuning 4 03-21-2008 07:48 PM
Synthetic Oil Not Good For Vtec? NoJokE General Tech and Maintenance 8 05-21-2003 11:07 PM
Vtec Issue On B16 Swap hondadriver HYBRID -> ED-EF / DA 6 05-20-2003 11:49 AM
