running obd1 b16 in obd2 civic with p28...need obd1 dizzy or obd2?? ppl on automotiveforums.com says i can use either one...can i use obd2 dizzy and run a wire to the ecu?
it depends on how your car is setup, what ecu are you running?
<a href=\'http://home.comcast.net/~projectxspeed/3rdgenteg.htm\' target=\'_blank\'>A Project in Progress</a> Get your ECU CHIPPED / buy ECU's CHEAP (uberdata, custom ecu maps, and more): <a href=\'http://www.hondaswap.com/forums/index.php?act=Msg&CODE=04&MID=36429 \' target=\'_blank\'>PROJEKTEG</a> |
i just gave u the setup im dogin " OBD1 b16 in OBD2 car with a p28..p28= OBD1 ecu.
Ride: RX5.7 Civic LS and Teg Ls
hmmmmmmmm this sounds very very familiar
i wonder why? o yeah that is my set up...lol to answer that question OBD2 car means OBD2 dizzy point blank, the wiring of the obd2 dizzy is different then the obd1. the obd1 has two plugs and the obd2 has one big one! hope that helps you out __________________
Check Out My Car Club www.HighRevCustoms.com and join the forums this is what happens when you are bored out your mind!!:| [[-]] (()) ||\|| ||)) //-\\ (( || \\// || (( my current baby http://i114.photobucket.com/albums/n.../myspacefc.jpg |
