hi ppl . i recently swaped a D16Z9 into my EK Chassis and used some OBD2 parts , as the crank pulley from my old D14 engine(european model) and the OBD2 alternator.
After the swap , i noticed that my starter was a little weak and my dash lights also , so i measured with a multimeter and i was surprised , because even with my engine running i get only 11, 5 volts.... I checked the belt , and tension is correct , i raise to 2000rpm and still 11,5 volts , so the crank pulley is not the cause ( the D14 one is a little bigger but lighter than Z9 one), so can i conclude that the D14 alternator is not enough to the Z9?? if the conclusion is taht i need to swap my alternator , i have another problem , because , into my OBD2 harness , the alternator plug is a 3 pins one as i show to you above: [/url]![]() And the Z9 alternator have this plug and wire colors: ![]() ![]() Itīs possible to cut and match them? or can you tell me the pin out of them? so i can match my need 4 wire OBD1 alternator to 3 wire OBD2 engine harness? thz alot for any help... Last edited by Beavis; 05-22-2008 at 04:02 PM. |
ok already , did some study on the honda manuals and have the conversion and wire match OBD1 and OBD2 alternator plugs:
Can be useful to someone: OBD1 :::::::::::::::::::::::::OBD2 Black /yellow::::::::::::Black/yellow : IG White /Blue::::::::::::::white /blue : Dash Charge light White/ Yellow:::::::::::White/green : Alt Control -OBD1 ECU pin A16 /OBD2 pin A19 Blue::::::::::::::::::::White/red : Alt Switch - OBD1 ECU pin D9 /OBD2 Pin C15 But the final question , can be the D14 alternator be weak to my new engine /setup?? |
Technician
Did you check what the alternator it's self was puttin out or just the voltage at the battery. If the alternator its self is puting out a weaker charge I would look into what each alternator's factory output spec is on both., if the d16 is the same as your d14, then I'd just get a new alternator for the d14. or, look into higher output aftermarket alternators for the d14
| OBD1 ALTERNATOR TO OBD2 WIRING | DEADLYACURACCY | HYBRID -> EG-EK / DC | 2 | 05-24-2008 11:53 PM |
| how to rewire obd2 alternator to obd1 car | dok | ECU's, Electronics, and Tuning | 3 | 05-23-2007 10:15 PM |
| how to rewire obd2 alternator to obd1 car | dok | Swap Articles | 0 | 05-20-2007 10:20 AM |
| obd2->obd1 alternator pin info needed | snozepp147 | HYBRID -> EG-EK / DC | 4 | 08-31-2006 10:02 AM |
| obd1 to obd2 alternator conversion | SixtySecondAssassin | HYBRID -> EG-EK / DC | 3 | 12-25-2003 06:55 PM |
