I am in the process of getting a 00 LS obd2b engine to put into my obd2a 97 integra... The ecu is the stock ecu, so an obd2a... I still have all the parts off my obd2a engine, what do I need to do to get it running properly? This project is starting tommorrow, so any advice is appreciated.
Ancient Member
Ride: RHD EG6 jrsc b18c :)
just use the stock obd2a ecu and the 97engine harness, and it will drop right in.
9/1/08 NEW PROJECT RIGHT HAND DRIVE EG6 doing it myself! 6/1/09 RHD on the road, now time for Body Shop 7/10/09 jackson gsr into rhd+hondata 91 rex ls/vtec b18b block, p30 pistons, pr3 head, p72 cams and ecu, 100% OEM HONDA PARTS, 100% converted to obd1 w/del sol harness NO JUMPER! 13.881@102 on street tires Reputation makes the world go round, if anyone has helped you and you feel that their post was worthy of some reptation, then give 'em a point!---, <-------------------------------- |
Ok that's what I was hoping to hear... If I were to put in a 94-95 obd1 into my car, same setup as above, what would be needed?
I'm asking because I have two options for an engine to buy tommorrow: An obd1 with 78,000 miles or An obd2b with 81,000 miles |
Ancient Member
for the obd1 it would be the same, but you would have to use the obd1 engine harness and there are a couple wiring issues (small issues) with the iac and the secondary butterflies. there are writeups in the refrence or swap section.
| Mid- Engine Integra! | BigDaddyLongstroke | Members' Lounge | 7 | 06-27-2006 12:07 PM |
| wiring help for obd2a ecu to obd2b motor | ricky05 | HYBRID -> EG-EK / DC | 3 | 04-17-2006 10:31 PM |
| HELP!!!! 96 Acura Integra LS Engine Swap | xxsuravianxx | General Tech and Maintenance | 10 | 01-10-2006 02:46 AM |
| will an obd1 engine harness function in an obd2a car? | Sinner | HYBRID -> EG-EK / DC | 6 | 01-05-2006 03:19 PM |
| FS: testing waters obd1 integra ls engine | Estorvito | Parts: For Sale/Trade/Wanted | 8 | 07-31-2005 10:29 AM |
