OK i had the engine started and it was working OK i needed to tune it but i didn't have it complete i needed to put the axles on and that was it, this is what i did after the last time i started
i put in the axles and the intermediate shaft i had to make room for the alternator so i used a pry bar and bend the fender area about an inch i don't know if it moved my tranny or what i put the wheel on and now it doesn't start it sounds like a car that is already started and you turn the key while it engine is on and it grins the fly wheel here is where i am stuck i took the starter off and checked the teeth on the starter and the flywheel and it was fine but why doesn't it start it wants to start but something is stopping it, it starts to want to start then stops because of that grinding noise when i took the starter out i had my dad turn the key and it turned while it was out so i was wondering if i put pressure on the engine and pushed the axle to tight in the tranny or if the tranny is really pushed in and i have to unbolt it and re-bolt it please guys help me out i am getting tired of working on this engine thanks guys by the way the axles move with no problem and there is no noise or an locking problem. __________________
started but running pretty rought have any advise pm me and let me know!! |
Try rotating the motor using a socket and bolt in the crank pulley,I had the same problem when I changed my Clutch just need to move the pulle a inch or two and try it again.
Hope that helps,Jim __________________
---------------1.7Ltr IB Spec Turbo Monster !!!--------------- '95 EJ Coupe, B16A Swap bored to 84mm with GE HD Sleeves,IB Spec JE Pistons,IB Spec SCAT H-Beam Rods,Type R LSD Trans,AEM Adjustable Cam Gears,Fluidyne Radiator, RC 750cc Injectors, AEM EMS Standalone With AEM Wideband UEGO O2 Controller, GM 3BAR MAP Sensor,GM Boost Control Solenoid,Turbonetics Stage 5 62-1 Turbo,2.5" Custom Exhaust, HKS SSQ BOV,Trust Type 31 Intercooler,ACT Streetlite Flywheel,ACT Streetdisc,ACT Xtreme pressure plate,Complete Energy Suspension Kit, 17" Katana Racing rims,Falken GRB FK451 225/35ZR17. -------Daily Driven,Full Interior,Complete Sound System------ ------------------------Certified Sleeper---------------------------- <a href=\"http://home1.gte.net/res0gy53/CARSWAP%20PICS.htm\" target=\"_blank\">My swap Pics (56K Beware)</a> |
thanks man but let me ask you this do you think i need to take the axles off and losen the tranny some to just relieve some pressure?
Was your Tranny already bolted to the motor and torqued down? if so then it would'nt have moved it. another ? can you rotate each wheel without it binding or feeling any grinding? if you don't feel anything you should be good.
#5 |
yeah i can turn both wheels and there is no noise or anything but i can understand how the starter will die like that out of no where so if i can turn the crank tomorrow with no problem then it is the starter if i can't then what should i look for?
#6 |
no, what I mean is turn the motor over by hand and then try and start it using your starter, mine kept grinding over and over, so I turned it by hand and it has been fine since!!!!!
![]() __________________
#8 |
The flywheel probably wasn't lined up with the teeth on the starter enough, and every time I tried to start the motor it kept grinding. So by turning the motor over by hand it let the starter engage properly.
Are you using the stock flywheel? __________________
#9 |
stock flywheel but what i don't understand is the engine started before but it is wierd, but when it turns it seems like it is getting locked man it is wierd could that be all of it tho even tho it seems like it is getting locked anything else i can look for?
#10 |
Are you turning the motor over with it in Neutral? if not, that may be why it feels like that, also it could be the compression of the motor itself. i have that problem(it gets harder to turn in some spots) when I am setting up for my leakdown tests!!!
#11 |
yeah it is in nutral beside i didn't let go of the clutch when i was starting the motor compression you think that is wierd this is getting wierder by the day man, so if the motor turns by hand put the starter back in and see if it starts from there, i got that should i take my valve cover off and check the timing over again?
#12 |
Yes, Try the starter back in it,then if it still does it try loosening the trans from the motor and realigning it.
#14 |
Try loosening it first and re-torque, as that is the easiest to do first,then if you still have the prob, then remove trans and inspect the clutch,disc and flywheel. also try spinning the Input shaft of the trans while you have it out to make sure it doesn't have a bad bearing. try the easiest stuff first then work to the hardest.
#15 |
ok kool i will try it tomorrow and i will let you know if it worked or not thanks for your help
#16 |
no prob,I've been in that boat before too
#17 |
ok i turned it and it got locked after 3/4 of a turn so it has to be my tranny it seems like it is locking how can that be?
#18 |
when you drop the tranny from the motor, try spinning the motor to rule out damage in the motor also!
#19 |
i put the car together yesterday i went to start it and it just grinded the starter and the flywheel i took the starter off and it was fine i thought maybe the tranny was locked took it off and fine i out a socket on the crank and it spun just a little bit and then the engine locked, spun the socket the other way and it locked again it locked both ways what do i need to do?
#20 |
could b e the tranny or the motor. only way to check is seperate them then check the motor for the same locking. if it does the same thing then thats not good!!!
if it spins ok then you know the motor is ok. then you have to check the flywheel,clutch disc, pressure plate. and trans __________________
#21 |
i got the tranny apart and i have the engine sitting there it spins but it doesn't fully rotate it stops then if i leave it alone for like 10 mins i can go back and spin it some more what is going one with my engine then because the tranny is moving just fine?
#22 |
check the cam timing on the cam pulleys in relation to the flywheel pulley. pull the spark plugs and try to turn the motor over. That will eliminate any compression from stopping it from turning, if you still have probs with it,it could be some sort of mechanical prob with the motor.
#24 |
omg what happened? Was it a "new" engine? Where did you get it?
The swap is completed. Dented oil pans will kill vtec. Now boosted! Vouches: Wanderinman |
#25 |
no it was a used engine i got it from the beloved HMotorsonline.com i called him and he is not going to take it back so i will never get anything from him again does anyone have any stock b16 rods i really want to get the civic it has been up for two months now thanks guys
