Oil Level Warning Light B16a
Old 03-27-2003, 09:41 AM   #1
Rep Power: 15 simonc is off the scale
After putting our B16a2 into a 1993 EG civic, I noticed that the red low oil warning light on the dash no longer works.
Does anyone know where on the engine this sensor is meant to be? I think we may not have connected it. (The light used to come on with all the other warning lights when the key was in the ignition position before switching the engine on.)
Thanks
simonc is offline   Reply With Quote
Old 03-28-2003, 06:41 PM   #2
thistownsucks...
hybrid89's Avatar
Rep Power: 33 hybrid89 will become famous soon enough
Send a message via AIM to hybrid89
Your oil pressure sending unit is located on the back of the block underneath the intake manifold. It is a single wire sensor in between the knock sensor and the temp sensor.(just above and to the left of the oil filter) It is the smallest of the three and should be all metal (no plastic). Hope this helps. Also, is your vtec working correctly. vtec is based on oil pressure(unless you are using a RPM activated switch to run it) Good luck
id rather have a hondata and a stock block
then a sleeved, pistons/rods combo and a hack or fmu
hybrid89 is offline   Reply With Quote
Old 03-31-2003, 04:32 AM   #3
Thanks!
VTEC is working fine and the oil is at the correct level. I just wondered why the light wasn't coming on. I think we may not have connected this properly.
How many forum posters does it take..... pissedoffsol Members' Lounge 51 12-01-2007 12:32 AM
97 Civic LX Warning Light ef9civicgen4 ECU's, Electronics, and Tuning 6 05-19-2004 11:59 AM
Low Fuel Warning Light peanut ECU's, Electronics, and Tuning 1 04-02-2004 01:27 PM
B16A Variants pissedoffsol Swap Articles 0 01-12-2004 02:31 AM
Check light on EF9 hb with b16a swap Jdubspeeds HYBRID -> ED-EF / DA 12 12-25-2003 12:34 AM
