Facebook Twitter
P.S. pump replacment in B16b/a engine swap into EK4 1.6lt
This is a discussion on P.S. pump replacment in B16b/a engine swap into EK4 1.6lt in the HYBRID -> EG-EK / DC forum
Hey guys ! I own a civic coupe 96 1.6lt (engine d16y8 with 127hp) and i want to do a b16a or b . do I need 2 replace the p.s. pump ?? (in the "HONDA ENGINE SWAPS" of Aaron Bonk says that an integra ...
Old 02-13-2007, 04:52 PM   #1
Default P.S. pump replacment in B16b/a engine swap into EK4 1.6lt
Hey guys !
I own a civic coupe 96 1.6lt (engine d16y8 with 127hp) and i want to do a b16a or b . do I need 2 replace the p.s. pump ?? (in the "HONDA ENGINE SWAPS" of Aaron Bonk says that an integra 98-01 P.S. pump must be instaled) ??
Thanks !
loverboy is offline   Reply With Quote
Old 02-13-2007, 07:22 PM   #2
welfare's Avatar
well, in my experience if you do a b swap and want to keep your p/s you have to get a p/s pump for the engine you are swapping in, Also you will need to replace the p/s pressure line that goes from the top of the pump to the p/s rack with the line for that engine.
for example if you do a gsr swap into a 95 civic you have to use a gsr p/s pump and a p/s pressure line from a gsr also.
Reason being that the d series pump does not mount correctly to the B block, Nor does the d series p/s pressure line hook up to the b series pump.
all in all it's only 2 parts that you have to buy, and usually when you buy an engine for a swap, it comes with the pump, so you would only need the pressure line.
welfare is offline   Reply With Quote
Old 02-16-2007, 08:27 PM   #3
nope, with EKs you can use the stock pump if you have the b16 power steering brackets. If you have the ls brackets on your b16 like me then you just take a piece of metal strapping(You know those strips of metal with holes in them) and cut a piece like 6 or 7 inches long and put a bolt through the bracket and another through the pump. Works great and it only took me like an hour.
killercannible is offline   Reply With Quote
Old 02-16-2007, 08:28 PM   #4
Oh yeah, i can take a picture of my custom bracket if you need it. Good luck.
Old 03-13-2007, 10:23 PM   #5
Default PS pump
Please post it!!
I need to know how to do it, it'll save me a lot of money.
Thanks from a Chilean Honda Tuner
speedborn is offline   Reply With Quote
Engine swap d16y8(obd2a) to b18c4(obd2b) UKDM, harness Q. hlt ECU's, Electronics, and Tuning 1 01-19-2007 04:45 AM
gsr whp 94_gs-r Engine Building 77 01-15-2007 09:00 AM
new here- engine swap jaylo Civic and CRX - EF 12 12-23-2006 05:54 PM
zc swap into 85 crx? devnjeff HYBRID -> ED-EF / DA 4 07-10-2005 10:09 PM
All Swap Info for EF Riceras HYBRID -> ED-EF / DA 2 02-07-2005 02:20 PM
© 2001-2013 HondaSwap.com
