is it possible to put a 98 acura 2.3cl motor in a 98 civic coupe?
Old 09-24-2009, 09:27 AM   #1
Greenhorn
Rep Power: 0 nuri is on a distinguished road
Default is it possible to put a 98 acura 2.3cl motor in a 98 civic coupe?
if so what do i need to do to do it thanks for the help
nuri is offline   Reply With Quote
Old 09-24-2009, 09:34 AM   #2
TTIWWOP
reckedracing's Avatar
Ride:  90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
Rep Power: 411 reckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
reckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
very much not worth it
The 1998 and 1999 models featured a 2.3 L (F23A1) with 150 hp
this would be the same as doing an F22 or H22/H23 swap into your car.
You need mounts, shifts cables, etc.
go to hasport.com and find the mount kit, then view the install instructions
that should give you a rough idea of how much of a waste of time its going to be for 30hp over a sohc vtec, and a heavy ass motor to boot
I'll blow a hole in your face then go inside and sleep like a baby.
reckedracing is offline   Reply With Quote
Old 09-24-2009, 09:37 AM   #3
HNFTuning
D15Beater's Avatar
Ride:  or die....
Rep Power: 19 D15Beater is a glorious beacon of lightD15Beater is a glorious beacon of lightD15Beater is a glorious beacon of lightD15Beater is a glorious beacon of light
Send a message via Yahoo to D15Beater myspace
F series is nothing to poke at...
D15Beater is offline   Reply With Quote
Old 09-24-2009, 09:38 AM   #4
Big Member
92stoccord's Avatar
Ride:  1992 Honda Accord, 1990 CR-X, 2003 Buell Blast
Rep Power: 100 92stoccord has a reputation beyond repute92stoccord has a reputation beyond repute
92stoccord has a reputation beyond repute92stoccord has a reputation beyond repute92stoccord has a reputation beyond repute92stoccord has a reputation beyond repute
B16 or B18C.
Originally Posted by Phyregod
The big goal of the cafe racers back in the day was to hit 100mph. If you put a 600rr engine in one, you're going to hit mach 3 and then get spokes and brake fragments lodged into your torso.
92stoccord is offline   Reply With Quote
Old 09-24-2009, 10:43 AM   #5
TTIWWOP
while i agree that an F series can definitely be built up nicely
i disagree that its the best bang for the buck
especially for someone that needs to ask if the swap can even be done
Old 09-24-2009, 10:58 AM   #6
HNFTuning
D15Beater's Avatar
Ride:  or die....
Yeah its a challenging swap, but im been looking into a F build for a while now.Ive been wanting to try this setup out.
F23 block (86.00 bore)
F23 crankshaft
F23 pistons
F23 rods
F22 head (milled 0.030)
3 layer OEM head gasket
H23 ARP studs
H23 intake manifold
B16 throttle body
H23 manual transmission
9.90:1 compression ratio W/ 2253.8 cc dis
0.000 piston-to-deck height
1.45:1 Rod / stroke ratio
0.040 shaved on head will yeild a 10.11:1 compression ratio
Old 09-24-2009, 12:25 PM   #7
Dark93DX's Avatar
Rep Power: 10 Dark93DX is on a distinguished road
its your car, so if you want to do it, then go for it.
Have you considered using the F-series block, but with an H22 VTEC Head?
K20Z3 EG - Installed, waiting for Kpro
LSD w/ 4.764 FD
B18A CRX
Dark93DX is offline   Reply With Quote
Old 09-24-2009, 02:36 PM   #8
Greenhorn
Default so yes or no is it worth it i have all parts i need i have another acura manual trann
well?
Old 09-24-2009, 02:40 PM   #9
HNFTuning
D15Beater's Avatar
Ride:  or die....
Man its really on you, we the forum wont have to drive your car. I would go for it honestly. Loose the F23 head, replace it with a F22a6 head, H23 intake manifold, H series transmission or get a few parts from Bisi and do a F/D swap. F22a6 in a civic..
Old 09-24-2009, 02:50 PM   #10
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
myspace
They do have quite a bit more torque though. Still, I think I'm going to have to agree on this swap not being worth it. If you're going to do an H/F swap into a Civic, then make it the H22...
PSN Network ID: BrutalB83
Old 09-24-2009, 04:10 PM   #11
Picture of Retarded Cat
Battle Pope's Avatar
Ride:  2007 Civic LX
Rep Power: 172 Battle Pope has a reputation beyond repute
Battle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond repute
I was thinking about this very same swap when I signed up for this site, it wasn't worth the cost then and it's not worth the cost now. For the same difficulty and price you could go with an H22 and end up with 200ish-hp.
Originally Posted by Jeremy Clarkson
A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.
Battle Pope is offline   Reply With Quote
Acura : Integra LS Coupe 1992 Acura Integra LS Coupe, Certified, Excellent Shape RSS-Bot Auctions 0 02-09-2008 09:13 PM
Acura : Integra SPORT COUPE 1993 ACURA INTEGRA COUPE-LOADED-AUTO RSS-Bot Auctions 0 11-14-2007 02:53 PM
New Motor For The Coupe.... EGProject Auto Multi-Media 12 03-20-2007 07:15 PM
92 teg motor into 93 civic coupe 93coupe HYBRID -> EG-EK / DC 3 03-23-2006 11:25 PM
Friend Has a B18C Motor In His Coupe...... CReX123 HYBRID -> EG-EK / DC 13 10-01-2004 08:55 PM
